Satellite radio antenna options?
xtremexj
I need some suggestions on what I can do for a different antenna mount. I have the magnetic one located just above the windshield but I get little if any reception with the camper on the truck unless I am southbound or eastbound. Any suggestions?
xtremexj
I guess I should have mentioned that it's an XM. I have seen those marine ones before but not sure if I want to string a cable from the camper to the truck. I was thinking about a fender mounted unit using a CB antenna bracket. I have to look some more but thanks for the links you guys.:)
Scoutman
I have Sirius factory installed on my Dodge truck. When I put the camper on it blocked the antenna completely and I ended up putting a magnetic one at the rear edge of my hood and ran the wire in to the sirius box behind the glove compartment. Try different places but that seemed to work pretty well on mine.
Smudge12
