Saurer 2dm 1968 Expeditionmobile build
nosedive
@-joz- Grüeziwohl vom einte Zürcher zum andere ✌ schöne Saurer!
Maybe it‘s just my browser, but I can‘t see your uploaded pictures anymore?
Cheers
themeec
Just an FYI, looks like it's an issue with the hosting service he's using for the images. @-joz- hope they get the service back up, and you don't lose any pics. Newcomer to the thread, and looking forward to reading more! :)
-joz-
Hoi nosedive en gruess zrug :) ! ja die scheiss internetsite woni all bilder ufeglade han isch irgendwie kaputt!
Oh no ..... thats not good :-(
i hope this hosting service wil come back again otherwise i have alot of work for upload these pictures again :)
ok i write a small introduction for these who dont know this post and i hope the pictures will come back again
i have all the pictures uploadet in facebook and i hope it will work with the copy from there
my truck is build in switzerland from the company names called "Sauer"
it has a 8.1 L 6 cyl Diesel engine direct injection with 135 HP
the engine is complete made of aluminium except the cylinder head made of cast iron
a 4 speed Synchromesh transmission with a fast Group and a normal Group so it is actually a 8 speed
a lockable transfere case with low range and a outlet for a mechanical winch
the rear axle has also a locker
the body consists of different materials ! back and roof consits of fiberglass, the Hood is made of aluminium and the front Fenders also made of fiberglass
here are a few pictures from the old posts
ok thats a few picture to report my "custom vintage offroad rig " :)
-joz-
ok now i continue my post from the rear suspension conversion
the next thing is i needed a construction to lift up my spare tire, my enduro bike and a big box for more storage
i have draw the whole thing on CAD
ok that looked good and i build it with construction tubes and some sheet metal parts that a factory lasered and bendet all parts are made of stainless steel
this is one of a edgebracket from the platform
ok it looks it would realy work :)
then i have mountet a 230v winch on the top for winch the platform up and down
i have take a 230v winch because it was cheap and i dont need to use big eletric cables for this
now i can storage my things in a good high clearance for better offroad use
-joz-
hello everybody !
here a little update for today
the next thing was is to build two boxes in the rear left and right for more storage
first i had draw it on the computer and designed it
it must fit to the fenders and rear it must have a slope angle ... and i made it also from stainless steel
the next thing was i need hot water for wash the dishes and for my shower
my idee was to weld a custom warm water boiler
because i have a little room behind my closet and i would put the boiler there
i put a 2000w electric heating coil in it and also i install a common engine
coolant diesel heater from webasto underneath the boiler
after i was finish with the welding i had made a pressure test
Anton2k3
Stunning work. One observation, I have a ship bought surecal calorifier which for all intents and purposes is the same as yours. However, the biggest difference is the insulation around mine. It means the tank stays hot for 48h or more. Definitely worth thinking about wrapping yours in some insulation to increase the efficiency.
-joz-
Jup... a insulation would be better but i have not enaught space for the insulation.... But when i start the heater it needs only 10 minutes to heat the water up to 75 °C (167 °f)
I had the choice more watervolume or insulation and i decided for more water :)
-joz-
Hello !
Now it's winter and time to use the woodstove
the exhaust from the woodstove is made of stainless steel
and i made a handflap for heat regulation
at the first testdrive some branches of trees got stuck between the campershell and the awning
now it needs protectors
i weldet a protector made of aluminium and i put a working light underneath
this lights are good for driving backwards and also for working in the night
