Savana/Express Lift Keys
Herbie
Rendezvous Conspirator
Your links are getting truncated (probably because you just posted them directly), so we can't see them. You'll probably need to post again and use the "link" icon to post the full link over some text.
TeleSteve
The Maxxcams allow you to change the indexing and can be used in more applications. Generally once they are installed where you want them you will never change the indexing cam again.
The standard torsion keys will work just as well as long as you get the right indexed ones from the start.
They will both allow some ride height adjustment once installed.
A few people have used the Rough Country keys on Savanna/Express AWD vans and were able to get the desired lift.
45Kevin
I got the entire "leveling" kit from Rough Country.
I used the keys and got about 2 1/2" of lift. I also used the front shocks and the u-bolts with my junk yard 2500 suburban springs for the 2 1/2" lift in the rear.
I have a set of lift blocks and rear shocks left over I'll sell to someone with a chev 1500 pick-up.
Smudge12
