Scan gauge on D2
EricG
Is anyone running on a D2? If so how does it do with temp and oil pressure. Thought about adding gauges but this may be easier.
Thanks,
trialrun
I run an ultra gauge (similar to the scan gauge) and it displays the temp and oil right from the computer readings which is great b/c the dash cluster has a huge variance on the temp before the needle moves. Highly recommend
Some Dude
Unless something has changed or they introduced a new model, the Scan Gauge does not read oil pressure or transmission temps on a D2. I have run one to monitor coolant temps and it works great for that.
EricG
Temp is mainly what I'm after oil would be a plus I'll check out the ultra gauge too.
vertical.dan
