See Level II tank monitor in my Arctic Fox
orangeTJ
See Level II tank monitor in my Arctic Fox is probably one of the most useful and meaningful upgrades I've done to it over the years.
I reads the tank levels in "percent" values instead of idiot lights.
It's made by Garnet Instruments up in Canada.
Here's a short video that shows it: https://www.youtube.com/watch?v=6e_xifbaY-4
In my Arctic Fox, I was able to access all of the OEM tank sensors and wiring, so I could install the new monitor. If you can't access the original sensors, and their wiring, it's going to be very difficult to retrofit to this system, unless you can run all new wiring, which is very difficult in most truck campers.
I disconnected the wires from the original monitor and the sensors, and reused those wires for the See Level.
pugslyyy
I added SeeLevel II Tank Monitors to my Bigfoot and agree - I'll never go back. Adding it to mine required some minor surgery and I ran all new wiring (so my old 3-level sensors still function)
vertical.dan
