DiploStrat
Polishing a brick.
Looking at settings to use with my Magnum inverter/charger in CC/CV mode. Really only use it for maintenance/top balance, etc. So the goal is to do the lithium iron equivalent of an equalization charge.
Battery bank is my home brew, 840Ah, made up of three 280Ah batteries, each of four 280Ah prismatic cells. All appear to be well matched and balanced.
Home now and I plugged in. Got what appears to be a perfect charge, all three BMS's reporting within 1.0% of SOC and voltage. Individual cells are typically within about 0.003v. When I went to bed the BMS's reported the SOC to be be 99%. (The Magnum reports the SOC as 100% and the actual hour count as +250, but that is probably because it has not had enough real cycles to calibrate itself. That is part of the frustration - dueling monitors.)
Current setting is throttled back to 60-70A (of a possible 100A), 14.2v absorb/target voltage, and trailing amps set at 6. These are scaled back from the AM Solar recommendations. As this is a home build, I am trying to be careful.
As the charger is in CC/CV mode, it shut off when the trailing amps hit 6A. There is no float; recharge is set at 13.2v. Of course.
Several gurus that I have spoken with have recommended a lower charge rate, especially in "maintenance" mode when I have all night - that is, I'm not in a rush. (Just because it will take a higher charge, doesn't mean you should do it.) The 14.2v was guesstimated from Victron's recommended settings and the 6A trailing voltage was backed off a bit from the recommended 4A, or 0.5A per 100Ah of battery.
Again, if the goal is full restore/top balance between trips - NOT a fast daily recharge, would love to hear your thoughts.
-- Raise the target voltage to 14.4v? This corresponds to Battle Born's target voltage.
-- Change the max charge rate? Obviously, during the day, the solar contributes as well. It has been suggested that with a capacity of over 800Ah, even 100A is low.
-- Lower the trailing amps to 4A. This would effectively increase the absorb time.
I think I am pretty close, but all thoughts and comments welcome.
N.B. Those of you with commercial batteries should always follow the recommendations of the manufacturer unless you are out of warranty and have some reason to believe that they are seriously mistaken.
N.B. 2 For this discussion I am not worrying about solar controller settings - only the shore power charger settings.
