gringorick
Been lurching forever. Thanks to everyone here for all the help over the many years. I am setting up my 1995 Toyota FZJ80 Land Cruiser for long-term expedition travel, and want to install a simple (i.e. inexpensive) dual/aux fuel tank. I cannot find any threads that discuss this setup, and am hoping to find someone who has done it, or who can tell me why I shouldn't do it.
I want to install a random fuel tank from another vehicle (15 gals or so) under the spare tire area. I will cut the fuel filler pipe an add a "tee" that will go the aux tank inlet. Both tanks will always fill at the same time. I will add a fuel pump (switched in the cab) to transfer fuel from the aux tank to the main tank when the main gets low. Fuel will be pumped into the main tank's vent line via another tee.
Seems easy enough, but I am sure there is something that I am missing.
Q1 - If I put the filler tee down at the lower end of the filler line, will it cause back turbulence and make the pump cutoff during filling?
Q2 - Will fuel transfer thru the vent line work?
Thanks for any help!
