The other side of the wall with the window requires a little more work. Since the window from the caravan sat in a 35 mm thick wall and my camperwall is made out of 2x2´s.
Had to make some corners too out of the foam to get a nice fit.
Lined the window with some thin woodpieces and filled all gaps with expanding foam.
After I have cut of the excess of the expanding foam, I can attatch the plywood sheet.
I did get the other insidewall painted twice and some stuff done on the truck to. Drained, flushed and refilled the coolingsystem and also drained and refilled the transfer case and front and rear drive axles. Now I have a repair manual for the truck and combining that with some youtube videos I´m actually getting a little more acquainted with the truck.:truck:
