Hill Bill E.
Oath Keeper
This is what I need!
http://www.expeditionportal.com/forum/showthread.php?t=32757
I took the XJ for a wheeling trip last weekend, and while I didn't sleep in it, I did check out the size for me to fit.
While the link above uses the pass seat full forward, mine hits the CB mounted on the hump.
But, the driver seat is electric, and moves waaayyyy forward, enough so that I can stretch out fully:coffeedrink:
I picked up a 3" futon mattress, that fit's the back good, so I just need to build a platform similar to the link above, making sure I can remove the front portion, so the rear seat is available when needed.
For the screens, using the mag strips works great. If they are glued to/sewn into the screen, you can just 'reach through' and pull the screen off from inside:snorkel:
But in all actuality, I'd only need them off when hitting the trail, in which case, I'd be exiting the back, and getting into the driver seat anyway, and could grab them.
I'm also going to rig the rear hatch, so it can be opened from inside.
Climbing in/out through the back door of the XJ is a bit much for me:elkgrin:
