Small van build (again!)
lqhikers
A few years back we did a small ford transit connect van into a week end camper
build is posted on vans had a lot of use then got bored.
Went back to a toyota 4x4 with Northstar pop up camper, happy for awhile until the
new full size transit came out ,had to have one did a conversion very happy with it
while we had it found we did not use it that much so it went to a new home. build
is also posted on vans.
Well have gone full circle new van is again is built as a weekender.
Ram Promaster city.
Did the normal floor, insulation, water, sink with electric pump, gray water, van battery,
solar, roof rack, awning, seating that coverts to bed, led lighting with dimmers,12v frig/frez,
cabinets, storage areas, window with screen in side door.
A few pictures to show build.
Les,lqhikers
MK13
Fantastic! Looks to be a great layout for such a small area. I really like your custom cooktop.
lqhikers
Looks pretty nice. Any issue installing the window in the slider?
Window came with inner frame that requires inch and half walls i deleted inner frame
removed edge gasket and used sealing putty instead then pop rivets to mount.
Since the blank door area is some sort of plastic it was easy to cut.
Whole job was less than an hour.
Can see out from drivers seat and have added ventilation.
LQHikers
lqhikers
Nice work??
How big is the bed?
Bed is 43"x76"
we sleep with our heads to the rear and when i did build i made the rear shelf area even
with mattress so as to have arm and shoulder room.
As a couple who have spent many a night in a small backpacking tent do not feel crowded.
LQHIKERS
Breezy78
