Snow Peak Addiction
Lennart
I guess it's up to the users to try all this out. Did you know the LG fire pit also sits into the IGT table frames? ;)
https://youtu.be/tDb-c6Ccfr0
There are just so many possible options yet it all adds up $$$, weight and complexity of setup / pack down.
That is funny, I didn't know that. He is 'fidgeting' a bit much to get it in but it seems to work in the end.
Perhaps we should start a list of the handy/hidden/unknown features of SP gear :)
"The snow peak kettle no1 fits inside the rice cooker CS-352, which fits inside the high end aluminum set CS-351. All the pots you need for some serious cooking, quite compact !" ;)
Chris Boyd
Not sure I'd like to sit there with all of that hot stuff near my lap! Half the fidgeting was the grill bridge, which is fidgety even if you're not stuffing into the IGT.
Does give me an idea to set it up with low legs and my 2U IGT just for a slightly elevated fire pit table. One of the main issues with the medium pit it doesn't put off a lot of heat. Maybe elevated a bit and everyone sitting around it, it might be warmer.
Now, I guess I need those adjustable legs!
cactusjk
Does the oven come with any bag? Would love to get a Drifta bag and that is always challenging for us in the US...
Umnak
Having an adjustable regulator helps. If you don't want to lug one around, the Kovea (LPG) propane /Lindal valve adapter has a miniature built in adjustable regulator via an adjustable set screw. There are various youtube videos on the product.
thanks for the response. I have the Kovea (LPG) propane /Lindal valve adapter, never even tried to use the set screw, but will give it a try with the 1 lb canister this weekend. I didn't realize this would work on a regular lpg tank.
landsharkman
comes with a case for the ceramic plate and a 4 way strap to hold all the parts together. so anybody have ideas for a case, i need one, for now it will just go in a duffle bag
stone23
