Car is SOLD
Hi guys, I decided to sell my beloved 1999 Mitsubishi Montero. This is a well-maintained and equipped rig. Here are the details:
Maintenance history:
174K miles. 3.5L SOHC engine. Timing belt replaced at 146K miles along with spark plugs and wires, intake manifold gasket, intake plenum gasket, camshaft position sensor, crank position sensor, CV boots, radiator hose, camshaft sprockets.
I've got the car at 167K miles and since then I did the following maintenance:
- All the fluids (differential, transfer case – Amsoil, transmission flush – Mitsubishi dealer, brake fluid - Motul). Replaced all the filters (gas, oil, air – just replaced the air filter for the 2nd time yesterday –Mohave roads tend to require frequent air filter changes)
- Front axles (Napa)
- Cluster lights
- Fixed the sunroof
- Fixed the shifter (common issue on this car, the ball disintegrates)
- Rear and front brakes
- All the front end (Moog tier rods, ball joints, stabilizer links, Timken wheel bearings)
- Added original Aisin hubs
- Re-geared to 4.63 (well worth the money and effort)
- Upcoming next weekend: replace the valve seals. Everything else works great, this was the last update I wanted to do to this car.
Equipment:
- Rear locker plus Super Select transfer case (2WD, 4WD Hi/Auto, 4WD Hi w locked center diff and 4WD Lo w locked center diff)
- ARB OME lift (torsion bars, springs, shocks)
- Rhino Rack roof rack 84x56 with 3 supports (this is the largest of the series, you can easily add a RTT if you want)
- BFG KM2 33x10.5 tires
- Odyssey AGM battery Group 34
- Kenwood stereo and speakers
- Custom rock sliders
- Custom ARB front bumper
- TJM raised air intake (snorkel)
- Smittybilt 9500 winch with synthetic line, Factor 55 ProLink thimble and wireless remote
- High Intensity LED Auxiliary lights
- Escape Gear front seat covers. Heated seats
- DIY sleeping&storage platform. I removed the 3rd row seats to make room for the platform
Sold
Carfax report available – clean title. VIN: JA4MR51R5XJ003038
I'm located in Orange County
Link to the maintenance tread
http://forum.expeditionportal.com/t...shi-Pajero-(Montero)-Gen-2-5?highlight=wasabi
Link to the sale listings by the previous 2 owners:
http://forum.expeditionportal.com/t...Adventure/Overland+Ready+w/Rear+Locker+-+149K
- Cluster lights
- Fixed the sunroof
Equipment:
Sold
