Solar Hot Water Heater
hdemetrious
I found this solar water heater.
http://shop.heliatos.com/Complete-2-...it-0770002.htm
It has a 2'x 2' panel that it circulates the water through. The pump that moves the water runs off its own solar panel so it doesn't take away from your power supply. The system plumbs into your existing heater so that the water is kept warm in your insulated tank. It also allows you to use your existing system for cloudy days. It costs around 500 and takes up little space. It seems like a good idea, does anyone have any experience with this?
vertical.dan
