I recently contacted the manufacturer of my Genius battery charger (hardwired into my van's 2 6V deep cycle batteries) to ask a question. In the course of getting information on using this charger with solar panels, the tech person informed me that it's not recommended that you charge your batteries from 2 sources at once (ex., solar panels and battery charger). I figured that I'd better remember to unplug my battery charger or turn off the inverter it would be plugged into, before hooking up my solar panels.
I also concluded that a switch to cut off the flow from the solar panels would be a good idea.
Then it occurred to me that those panel shouldn't be on when I'm driving either, since the interrupter switch will cause the alternator to start charging the deep cycle batteries once the van is running and the van's battery is topped off.
Is there some kind of switch that I can install inline with my solar panels to prevent them from sending a charge when the batteries are getting juice from a different source? The interrupter switch already takes care of the alternator as I understand it.
Electrical is black magic to me. Any advice or corrections of my understanding of things would be greatly appreciated.
Thanks. John B
Thanks. John B
