Solar or Generator
mikracer
I would make sure the Honda 2000 has enough juice to power your A/C. Seems like some of the larger A/C units need more power than the 2000 can put out.
Scoutn79
That is one quiet generator there. I think normal conversation is about 64db. If you had a little sound box for it you would probably never hear it running.
If the only reason you are bringing a genny is for running the AC and a coffee pot you might think about doing coffee on the stove the old fashioned way or going instant and using a small 12v fan instead of the AC. The fan obviously won't keep you as cool but it would help.
If you could get by without the AC and coffee maker you could use solar as much as possible and supplement that with jumper cables or a dedicated dis-connectable cable system from you truck to top off the batteries as required.
Darrell
Darrell
PuddleJumper
iStan814
