Solar panel to controller wire gauge
zidaro
OK, this seems like a huge rookie question, but i need to feel better so help me out please.
Im installing solar on my Popup Northstar TC650 Slide-in.
Link to post on my Thread: http://www.expeditionportal.com/forum/showpost.php?p=721370&postcount=43
AMsolar 100W panel with factory 10/2g 8" leads already on it- says 4mm on it.
Morningstar MPPT 15A Sunsaver Charge Controller mounted close to battery and fused with 25A breaker.
I want to use:
stranded copper cable-
8g cable from panel to controller - ~15ft. run
4g cable from controller to battery- 3ft. run
Is this adequate?
Sorry, it has prolly been covered a hundred times i just could not find what i was looking for.
thankyou in advance,
aaron
DontPanic42
I want to use:
Is this adequate?
aaron
That's the way I did mine. I have been running my AMSolar since about 2006.
zidaro
4mm = 12g i think.
BTW- I really am not great at vehicle electronics, trying to learn as I go here.
Anyone have great ideas/product for penetrating the roof with 2 8g. cables?
LandCruiserPhil
With #8 @15' you have less then 1% loss at the rated output.
wrcsixeight
You will not regret using 8awg panel to controller and 4awg from controller to battery. I used 12 with a 130 watt panel, and I am kicking myself. It is especially important with MPPT controllers. Also put the controller as close to the batteries as you conveniently can without them sharing the same space.
Here are some good through the roof products for the wires.
http://www.mcmaster.com/#catalog/116/825/=940uyv
I used tinned marine wire and 3m 5200 adhesive sealant through my fiberglass roof. No leaks, but no chance of removal without serious tools.
zidaro
Thanks WRC, i hadnt found those from mcmaster.
Here are 2 options for roof penetration:
http://www.defender.com/product.jsp?path=-1|328|49758|112306|316467&id=1351907
http://www.jamestowndistributors.com/userportal/show_product.do?pid=661&BASE
[ame="http://www.amazon.com/Ancor-765004-Marine-Electrical-0-Gauge/dp/B000NI01A8/ref=pd_rhf_p_t_3"]Amazon.com: Ancor 765004 Marine Grade Electrical Wire Seal (Round Cable, 1 to 3/0-Gauge, 3/4-Inch NPT, UV Black): Sports & Outdoors[/ame]
I'm liking the rectangular multi-mount best.
and thanks for the wire size advice as well, it is making me feel better. Last thing i want is undersizing. but overkill is overkill too.
WonaWarrior
