jonnypage
Say Hello to Kenny Rogers (aka. Our Toyota 4Runner)!
Located and Squamish BC CANADA
$16500 CAD
305,000 and going up slowly
3rd gen limited with e locker
This fully-equipped overlanding vehicle is perfect for those looking to get off the beaten path and explore the very best of the backcountry. It’s fully equipped for days off grid Making it ideal for those wanting to get off-road, hike into the backcountry or sleep on route.
Interior Description:
At first glance, it may look like he’s just another vehicle – wrong!
The rooftop tent is ready for all your epic rooftop dreams! This means you can camp and sleep anywhere you find a cool place, without having to find a flat surface for pitching a regular tent ( He has a custom bumper which is equipped with extra water, fuel, a 5lb propane tank and a drop down cooking surface which fits your very own camp stove The tailgate is equipped with pot lights (no more one-pot mystery meals in the dark) and the interior of the vehicle has LED strip lighting with its very own dimmer switch. Because cold beverages are essential in the hot backcountry, we have a 35L fridge to hold your food and beer (it also fits a bottle of wine; don't judge us for knowing this!) This fridge has its own temperature control, so it can also be turned into a freezer if you desire. The fridge is plugged into Kenny’s internal wiring system and runs off it’s very own battery. Even though the fridge and lights draw very little power, we don’t want to leave you stranded without a starter – which it why the battery that powers the fridge is NOT connected to the starter battery. Just in case, we even have a solar panel that is equipped to help you power everything else you may need … such as your phone charger or laptop. There is one 12V-110V inverter located in the front of the truck, with two additional USB chargers at the back.
In the interior of Kenny, we’ve got plenty of space for you to stay organized.
Behind the driver and passenger seats, all the way to the back of the tailgate, is a wooden platform which can store plenty of storage bins underneath for clothing or shoes. There are also strap down points on the top of the platform for any additional items you have.
The real #StorageGoals however are located in the back of Kenny in the form of 2 long, deep pull-out drawers. Located in Squamish. The real party trick this is Registered as an RV so insurance is super cheap! Needs nothing. Only selling due to Going traveling in our new vehicle.
4runner work
June 2018
Timing belt,
Water pump
Fan clutch
All belts
Radiator
Added external cooler for Trans
Front brakes ( tundra upgrade ) and rotors
Rear drums
Diff breathers extended
Full Toytec lift kit with superflex coils with new SPC upper control arms
lower control arms and greasable bolts
Air lift rear air springs
BCC Pan hard bar ( new ends 7/22)
Front Diff drop
Rear bump stop extension
New upper and lower trailing arms ( rear)
Full fluid changes
New injectors
New valve cover gaskets
New NGK plugs
Rear Polyurethane Body Mounts from Sonoran Steel
Custom dual battery mount under hood
Group 24 Deep cycle battery
Dual battery isolator with dual fuses and circuit breakers and aux Blue Sea fuse panel in rear
inverter in the front for charging laptops/ cameras etc
New bluetooth head unit
6 bank switch panel in trunk controlling lights, and battery charge indicator and usb outlets run of AGM aux battery (3 switches spare)
New cv boots with stretched boots
Custom rear trunk platform with two large full extension slide outs , Vinyl covering inside and out ( can be left in with seats)
New gas lift gate struts
Limo tint on rear windows
Remote central locking
Rear Hybrid coastal off road bumper with backup lights
3jerry cans 2 water one fuel ( interchangeable)
Removable bike rack
Spare tire fits under vehicle ( space saver not full size)
Custom swing out with 40l water and 20l gas and 5lbs propane
8/2019
Custom full length roof rack with sunroof opening and solar panel
Brand new k02 tires
Tepui Roof top tent with skylights and rain cover/F
Fridge Dometic CFX 35 2 years old can be negotiated in the sale,
2022
Winch installed ( still never used )
New front pads and rotors
New steering rack and tie rod ends (OEM )
New lower ball joints (OEM)
New injectors
New start battery, lower plenum gaskets and coolant pipe o ring replace
Full fluids changed
Rear main oil seal replaced. OEM
Startermotor rebuilt
New NGK plugs
New OEM ignition leads
New Toyota rear latch mechanism
4/23
New Toytec super flex rear springs
New Eibach front shocks
New lower rear trailing arms
Spare parts included.
All new AC compressor, receiver driver and other misc AC parts ( was bought incase AC needed a refresh )
Spare used injectors ( Common issue on 3.4)
New steering wheel cover( not installed but is the sew on type)
Misc parts removed during lift / Parts that where pre emptively removed but are still good.
Not so good. Front drivers seat stitching is coming apart.
Center seal belt has a dog chew mark
Some scuffs on the body. We take this into the backcountry REGULARLY. No majors dents or scratches tho
Frame is perfect. Always pressure washed and re fluid filmed every year. Rarely winter driven and garage stored
Can be customised for sale eg front bumper or modifications.
Will deliver for serious buyers
$16500 CAD
4runner work
June 2018
Timing belt,
Water pump
Fan clutch
All belts
Radiator
Rear drums
Front Diff drop
Full fluid changes
New injectors
New NGK plugs
Removable bike rack
8/2019
Brand new k02 tires
2022
New injectors
Full fluids changed
New NGK plugs
4/23
