SOLD! 2007 Ford E350 Cargo - $6000 obo
WVI
5.4 V8
Auto
3,73 Gears
Cruise
Power Windows and Locks
Power Tow Mirrors (manually telescoping)
Tilt Wheel
Tube Steps/Running Boards
Mileage when I bought it: 48882
Current Mileage:120800
Years I've had it:6
Maintenance/Work done on it:
Regular oil changes
Limited Slip installed
Trans fluid completely changed
Transmission/Hydraulic inline filter installed
Coolant system flushed
Idler & auto tensioner bearings and pulleys replaced
Water Pump & Thermostat Replaced (Replaced as GP when the pulleys were)
New upper and lower ball joints
All steering linkage replaced
Adjustable Caster/Camber bushing installed
All new brakes (Fronts are 2008+ version)
Factory Aux Battery Tray installed
All new shocks
OEM Steering Damper installed
Fast Charge double USB plug installed
Fuel driver module and fuel pump replaced
Painted roof with Rustoleum Equipment paint as the factory paint was peeling on the rain gutters
New battery last year
All new catalytic converters
Interior Cargo Area:
Sound deadening on walls and cargo doors
Floor cleaned and spot painted
Rear half of van floor is 3/4" stained ply
Front half is 1/8" ply over hard foam insulation with 1x2 frame
Access in floor for easy fuel pump R&R
Side walls are gray plastic upfitter panels with partial vapor barrier
Ceiling-Unfinished
Cargo door panels are assorted OEM fiberboard/plastic upfitter panels
I still have part of the original bed that I built and was for storage. It’s not currently installed
2ea 5gal jerry/water can holders
Spare Parts Included:
OEM Seat Cover
OEM Seat Foam
OEM Cargo Mat
4ea pop out windows for the four cargo doors
Front & Rear Bumpers
2 or 3 sets of old school interior flat door panel assemblies (driver & pass sides)
Old school windshield visor
Contractor ladder rack set
OEM differential assembly
Extra Dog House assembly (cup holder and pull open storage portion)
Assorted electrical switches from other Ford Van interiors.(window and lock)
A couple of spare rims and tires
Front Turn/Corner Marker Lenses (I installed older version with the amber color in them)
Third Brake Light Lense (the one in now is siliconed in)
Firestone Ride Rite airbag brackets
OEM Cargo floor mat
OEM hub caps
Side mirrors
The Bad:
Has a couple small dents and scratches ( I just scratched/dented the side cargo doors 2 weeks ago)
Rear drivers wheel well showing rust on outer panel
Hole in floor beneath driver's feet. Patched and no issues
Runs and drives well.
This has been my daily driver since 2015
Located in Southern Illinois
Would consider a partial trade of a set 17/18" Tundra rims or shell for an '07 Crewmax
Mitch Bears
