spon
WHAT IS IT?
This is a decommissioned Bureau of Land Management (BLM) “Hot Shot Buggy”. Hot Shot Buggies are crew carriers used by BLM and Forest Service firefighters. These trucks are meticulously maintained due to their use. There’s a bit of nostalgia in buying this!
Same exterior feel of an ambulance but without all the built-in cupboards, shelves, wiring, etc. that you would have to work around and/or remove. This is a clean slate to build however you would like.
THE DETAILS:
Located in Bend, OR.
4X4, 6.0L, 8CYL, Diesel, Automatic Transmission, Air Conditioning, Power Steering. This is the last year of the 6.0L and every year had improvements. Check out this link for more details: http://www.powerstrokehub.com/6.0-model-year-changes.html.
The commercial trucks had a detuned engine vs. the pickup trucks and thus don’t have as many of the issues as the higher horsepower pickups.
VIN: 1FDAF57P67EA76947
Miles: ~82,360
Outer dimensions:
Height: 114” (9’6”)
Length: 139” (11’6”)
Width: 90” (7’6”)
Overall length: 283” (23’7”)
Inner dimensions:
Height: 67” (5’6”) - Could easily be made 5’8” through center by removing the secondary 2x2 studs.
Length: 133 (11’)
Width: 86” (7’2.5”)
WHAT WE’VE DONE:
We have gutted, prepped and gone through all the systems so you can easily start your own build! We have over 40 hours of labor into gutting, prepping and fixing.
Vehicles were purchased to upfit and sell but life circumstances have changed so we are offering as-is.
As-is this truck handles very well off-road, on 4x4 trails, on the highway, etc.
SOLD: We have a 2002 Ford F550 4x4 Hot Shot Buggy 7.3L Diesel Manual Transmission $29,500 also for sale. Check out the listing here: https://expeditionportal.com/forum/...-3l-diesel-manual-transmission-29-500.225243/.
THE DETAILS:
Miles: ~82,360
Outer dimensions:
Height: 114” (9’6”)
Width: 90” (7’6”)
Inner dimensions:
Length: 133 (11’)
Width: 86” (7’2.5”)
WHAT WE’VE DONE:
- Driven from Safford, AZ to Bend, OR with no issues
- Removed all interior components down to studs including fire crew seats, walls, subpar insulation, flooring, ceiling, AC/heating unit and lines, and back wall
- Cab AC recharged after rear AC removed
- Oil, filter and fluids changed
- Engine and interior degreased and washed
- Fixed and straightened some loose or bent body parts
- Normal wear and tear on vinyl seats in cab (see pics)
- A few Dings on a couple wheels
- Tires have decent tread but a couple tread chunks missing and
- Driver’s side window tint needs to be removed and/or replaced
- PA is not functioning
- Cigarette lighters in the console are not functioning
- Dome light switch from the drivers side is not functioning
- Side door lock is not functional
