[Sold]: 2009 Adventure Trailer (AT) Horizon - RTT, kitchen, 18g water, 10g fuel [NorCal]
jdzl
With camping season coming up we've been evaluating how much we're going to be able to get out there and it doesn't sound like it's going to be much due to projects -- wondering if anyone else can make use of this.
2009 Adventure Trailer Horizon w/ TAAS (air suspension)
More Photos:
Factory options/features
- Eezi-awn Series 3 1800 RTT in good condition with brand new (last month) exterior cover
- Kitchen with Partner Steel stove, cutting board integrated into kitchen "door"
- 19 gallon poly water tank, shurflo pump and various quick connects to reconfigure hot water / cold water / shower / faucet on the fly
- Powder coated tongue box with shore charger, newer group 31 AGM battery, shore power hookup, multiple anderson power plug ports throughout
- Jerry can holders (2) [lockable], with (2) steel jerry cans
- Fiamma awning with telescoping mounts
- Lock-N-Roll hitch (including vehicle side)
- Two 10lb "pancake" propane tanks / mounts (both with current certification)
- Accessory 2" hitch on rear
- Aux rear light
- All compartments are keyed alike, with padlocks for jerry can holders and cargo box tilt lid.
Later additions/work done
- LED lighting in main box and kitchen box
- BFG KO2 tires with full spare (no mount), Land Rover bolt pattern
- Pelican case mounted instant propane water heater with quick connects to faucet and water tank
- New OEM poly trailing arm bushings / rods from AT
- Replaced Eezi-awn cover with brand new one from Eezi-awn (as above)
Manufacturer Specs
Overall Length124"_________________________________________________________________________
Overall Width68"
Main Cargo Box40"W x 30"H x 54"L
Side Box14"W x 14"H x 54"L
Nose Box(31" W + 15"W) x 19" H x 16.5"L
Cubic Capacity54 Cubic Feet
Water Tank19 Gallons
Propane Tank11 lbs (x2)
Gas Cans5 Gallons each
Base Trailer Weight1100 lbs. (guessing closer to 1500-1600lbs as equipped)
Payload1600 lbs.
Ground Clearance24"
Box Material14 Gauge Zinc Washed Steel
Chassis Material2" x 3" x 1/8" steel tube
Bumper material2" x 5" x 3/16" steel tube
Trailer is located 30 minutes outside of Redding, CA (96001), happy to work with a shipper if necessary. Trailer is e-titled in CA, with PTI (permanent trailer) registration. Happy to chat more about it via PM or by phone (shoot me a PM for number).
Price is $10,500.
Thanks for looking!
jdzl
Still available. I don't think Eezi Awn offers an annex for this model but could probably rig one up since bottom of tent is solid (oiled) plywood unlike the honeycomb of some others.
guapstyle
