High Water
Baja Bliss
2009 Honda CRF230L SOLD
9495 miles
Price: $3150 Reasonable offers considered
VIN: JH2MD37149K102027
Clear South Dakota Title
We have owned this bike since 2012 and it has been very reliable with only basic maintenance required. This model has an oil screen instead of a filter, so I change the oil more frequently than specified because it is so easy to do and I didn’t want any wear. Cosmetically, it has bumps and scrapes and I have tried to fully disclose that in the photos. Everything works and starts and runs on demand.
As the bike sits now it is lowered with a Koubalink on the rear shock and the triple clamps dropped 1cm down on the forks makes the static seat height 35”. There is very little static sag. The preload is adjusted to maximum.
Accessories/modifications:
Tusk heated grips
Cycra bar guards
ROX risers for 7/8” OEM Bar
Flatlands racing skid plate
Flatlands Racing tail rack
Aluminum exhaust tip with screen
Canister removed
Carb jet change for elevation but this model is not very sensitive to jetting, it just runs.
Koubalink lowering link - I have the OEM link should the new owner want to returned to factory height.
Recent maintenance:
Current odometer 9495 miles
Last full synthetic oil change 8600
New 520 DID O-ring chain and sprocket 8400
Front tire 9150
Rear tire 8000 it is about 50% worn.
New EBC clutch 8000
Last Valve check at 9100
Front brakes were change last year when a fork seal (7500 miles) let go and got oil on the pads
Rear brake pads were changed this year.
Last year the valve cover gasket was weeping oil so that was replaced
New Battery 2022
Spare parts included with sale:
Used Dunlop 605 front tire but still has many miles left. I change the front tire occasional based on planned riding conditions. We have been riding a lot of off road this year so it has a more aggressive tire on it. If the buyer wants, I will swap the tires out prior to purchase.
OEM Clutch lever
New Shift lever
New air filter
Sprockets
New front brake pads
New grips
New OEM 7/8” Bar
Miscellaneous nuts and bolts
9495 miles
Tusk heated grips
Cycra bar guards
Canister removed
Recent maintenance:
Front tire 9150
New EBC clutch 8000
New Battery 2022
OEM Clutch lever
New Shift lever
New air filter
Sprockets
New grips
New OEM 7/8” Bar
