TommyArgh
Ive been thinking about tossing around the idea of another project which means this would have to go.
It currently has 85,800 miles as it is a daily driver. It is in great condition with the exception of a few trail pinstripes that could be buffed out.
Ive been keeping track of the trucks maintenance and upgrades since the day I bought it as well as the receipts. There has been a few iterations up until its current state.
10/16/18 Purchased Vehicle 65,649 Miles
10/17/18 Touched up a few paint spots
10/18/18 Installed Weathertech mats and bed mat.
10/20/18 Had windows tinted with new ceramic tint @ New Wave. Installed missing cup holder inserts up front and installed Pop & Lock talgate handle.
10/21/18 Installed an Extang Hard bed cover I found on FB Marketplace.
10/22/18 Removed all exterior badging.
10/24/18 Installed wheels and tires. Already had two spare tires. Just had to buy two more wheels. Mounted and balanced by Waukegan tire.
10/26/18 Installed color matched grille I found on Car-Part.com. Made a huge difference without the chrome.
10/27/18 Removed TRD bed stickers.
11/02/18 Undercoated with 3 cans of Fluid Film. Will touch up some areas in a few days.
11/17/18 Swapped out the bed cover for a color matched cap I found in Grand Rapids, MI for $500.
11/30/18 Had a chip in the windshield replaced by Gerber onsite.
02/08/19 Oil change 67850 miles synthetic.
04/03/19
Installed ARB Roof rack.
04/11/19
Scuffed and painted drivers side door sill to install door sill scuff plates.
04/13/9
Installed Element Led Amber Fog Cannons with Cali Raised H11 to Deutsch connector. Element sent prototype mounts for Tacomas to test out. Also fixed a few bed cover seals that Extang covered under warranty.
04/20/19
69,500 miles
Lift Install day
Premeasurements
LF - 34 1/4
RF - 34 1/2
RR - 35 1/2
LR - 35
After Lift
LF - 37 1/2
RF - 37 1/2
RR - 38 3/4
LR - 38
Also installed ECGS needle bearing bushing replacement.
04/22/19
Had to reset Maintenance Required Light at 1828 miles.
Installed Plano Case onto roof rack.
04/30/19
69947 miles. New Falken tires installed.
05/04/19
Plasti Dipped rear bumper
05/05/19
Installed bed bars and RTT.
05/13/19
Installed XL Quick Fists for recovery board roof rack mounts.
05/14/19
Installed new tailgate cap replacement.
05/25/19
Put tonneau cover back on, over bed rack mounts.
06/02/19
Installed Pelfreybilt Fuse Plate holder, Blue Sea 6 fuse block, power & ground wires with fuse, Element Led Ditch lights and CH4x4 custom switch.
06/03/19
Bed rack end caps came in. Installed stubby radio antenna.
06/07/19
Wired the fog light mod. Installed Ultraguage.
06/19/19
Installed Rhino Rack Sunseeker 6.5ft awning and HD mounts.
07/07/19
Traded the tonneau cover straight up for another topper. Installed the fridge, battery, and noco battery charger in the bed.
07/08/19
Installed roof rack on topper and some weather stripping around the tailgate.
07/11/19
Installed the Renogy 100w solar panel on the cab roof rack and solar charger on battery box.
07/17/19
Received and installed the fridge insulated cover. Seems to be holding temps fairly well. Battery and solar has been more stable and I am able to run a cooler temp setting.
07/22/19
Installed 30amp inline fuse on the solar panel. I also installed a 100ah battery. Hopefully this is big enough for the fridge to run several days.
07/22/19
Oil Change full synthetic 73,172 miles.
8/10/19
Built a better box for the house battery using the components from old setup and a new Noco battery meter. Levels have been fluctuating. Im waiting for a Renogy DC to DC charger to arrive.
10/27/19
Sold the fridge mostly because it wont fit in the new camper. Took off all of the roof accessories. Still have to clean out the bed. Did I mention a new camper?
11/01/19
Installed FWC internal camper mounts
11/02/19
Sold the cap. Installed Stall Mat to even out the bed floor.
11/03/19
Picked up the Four Wheel Campers Finch.
11/09/19
Installed rear airbags. Rotated tires.
01/08/20
Installed Dobinsons Snorkel.
02/24/20
Installed Midland Comms
03/07/20
Installed SPC Adjustable Upper Control Arms and Daystar Airbag Cradles
03/08/20
Installed Attwood plug for truck to camper charging.
03/09/20
Alignment done. 77990 miles.
04/10/20 Installed Demello front bumper and Smittybilt winch.
4/18/20 Oil change. 78,902 miles. I also brought the truck back in for a third alignment. I was still having rubbing issues on the driver side after Waukegan Tire said they corrected in. False. I got a good recommendation to go see Mike over at Berry Tire. He got everything corrected and it drives flawless. I will definitely be going back there.
05/02/20
Swapped coil springs from 885 to higher rate 886 to compensate for the bumper and winch. 71,970 miles.
05/07/20
Installed BAMF rock sliders that I refinished and installed window vent visors.
06/26/20
Brought truck into Classic Toyota to have the Secondary Air Pump/ Diverter valve and frame coating done under recall.
07/18/20
Installed the 4xinnovations rear bumper. Still need to finish the rear tire swingout setup and install.
Finished up the swing out a few days later.
08/08/20
Painted all of the wheels gloss black. Should compliment the new camper nicely.
08/15/20
Installed the AT Overland Atlas camper!
09/03/20
Finished up the camper battery system. Installed two 105ah batteries, Renogy DC to DC charger, extra usb outlets, extra 12v socket for the fridge, and a worklight on the inside of the rear hatch for cooking and cleaning. I also installed a brighter reverse light on the tire swing.
09/13/20
Installed Victory 4x4 bed stiffeners and wired in the camper third brake light.
10/04/20
Updated the battery box to an aluminum one. Needed more rigidity and space saving.
10/04/20
Changed the oil. Toyota Filter and drain gasket. Mobil 1 5W30 Full Synthetic.
Currently the truck is equipped with AT Overlands Atlas model that I took delivery of in September of this year. The options I added for that camper were the Fantastic Fan Roof Vent, Awning mounts in which holds the Rhino Rack Sunseeker 6ft awning, and the electrical panels that house all of the wiring, lights and switches, usb plugs, and 12v plugs. I have a total of two weeks worth of nights spent in the camper.
There are probably some things I may have forgot to list but do not hesitate to ask as I will be completely transparent with you. For the combo Im looking to get 40k. The truck is located in IL. Please feel free to send me a direct message!
04/03/19
04/11/19
04/13/9
04/20/19
69,500 miles
Lift Install day
Premeasurements
LF - 34 1/4
RF - 34 1/2
RR - 35 1/2
LR - 35
After Lift
LF - 37 1/2
RF - 37 1/2
RR - 38 3/4
LR - 38
04/22/19
04/30/19
05/04/19
05/05/19
05/13/19
05/14/19
05/25/19
06/02/19
06/03/19
06/07/19
06/19/19
07/07/19
07/08/19
07/11/19
07/17/19
07/22/19
07/22/19
8/10/19
10/27/19
11/01/19
11/02/19
11/03/19
11/09/19
01/08/20
02/24/20
03/07/20
03/08/20
03/09/20
05/02/20
05/07/20
06/26/20
07/18/20
08/08/20
08/15/20
09/03/20
09/13/20
10/04/20
10/04/20
