Pre-TAAS Torsen Bar Suspension
Steel Powder Coated Nose Box
2 Fuel Can Mounts
Slide out Partner two-burner Stove w/ 2 Propane bottles (10# Each)
Built in Cutting Board on kitchen side
Auxiliary 12V Wiring in nose box and main Box with 2 12v sockets, 1 Dual USB - all Blue sea
Blue Sea voltage gauge on front box
2 Blue sea Fuse boxes (front/rear)
LED Lighting in main boxes
Solar charger/controller
2x 100W Semi Flexible solar panels
NoCo Battery charger/conditioner with external shore input plug
2x12v Ports, 1X Blue Sea Dual USB plug on Nose Box
Deep Cycle Group 31 battery
Electric Braked Axles with Breakaway system
New Spare Timken Bearings
Treg 360 Multi Axis Hitch
Rhino Rack Batwing 270 degree awning on custom high Mounts, I have some tall friends so, fits a 6’5” person under the awning.
Wired for Fridge
Tembo Tusk Fridge Slide
23Zero Byron - Cal King Sized tent, with Annex (new Feb 2019) On custom high racks.
Racks allow for storage under neither tent - Enough room for a kayak.
Original AT Racks included - can be used with the High Racks for 2nd level (Not installed)
19 Gallon Water Tank, Surflo 3.8gpm water pump in nose box, Front runner faucet on right side.
Complete set of Keyed alike padlocks
Pneumatic front wheel/landing gear (AT)
Will Come with New Wheels and Tires on a Jeep TJ pattern (5x4.5), tires will be apx 32”
Defender wheels and tires do not convey, unless extra.
Garage Kept.
Pictures coming Sunday when its dry and i can get everything deployed.
Overall condition is very good, used mainly as a base amp type trailer and not towed on trails. some powder coat failed on the insides of the door, treated and POR15’d.
tent has maybe 10 nights in it, annex has never been used.
$10k
Located in Apex NC
2 Fuel Can Mounts
Wired for Fridge
Garage Kept.
$10k
Located in Apex NC
