SOLD!!! For Sale: 2021 Toyota Tundra SR5 Double Cab with AT Overland Atlas Topper
anand
The time has come to move on from this project and onto the next, so after ~15 months the Tundra needs a new owner.
It was purchased at the end of December 2020, and currently has around 45k miles on it. This thing has taken us coast to coast multiple times, and up and down both coasts without a single hiccup.
All modifications/specs are available upon request, but I'll give a brief breakdown:
2021 Toyota Tundra SR5 Double Cab - 6.5' Bed - SX Pkg
  • Toytec Aluma 2.5 coilovers, SPC UCAs, Aluma 2.0 rear shocks, Dobinsons HD full rear leaf pack, diff drop, carrier bearing drop, adj. shackles, bump stops
  • ARB Front bumper w/ ARB Solis Spotties and Diode Dynamics SS3 Max and SSC2 Pro lighting; Comeup 12.5RS winch w/ Factor55 FlatLink E
  • LFD Off Road Steel Front Skid
  • Level8 MK6 18x9's w/ 35x12.50 BFG All Terrains (with a skinny 35" spare)
  • Dobinsons Snorkel
  • LRA 46 Gallon Fuel Tank
  • ARB Twin Air Compressor
  • All LED everything inside and out (upgraded to OEM TRD Pro LED headlamps and Diode Dynamics LED bulbs in everything incl. turn signals/etc). Diode Stage Series 50" lightbar on the front of the topper, and Diode SS3 Pro in the rear bumper as well. 11 KC Cyclones as white ground lights, and 2 more in yellow under the rear
  • Dual AGMs batteries (27F as main, 31 as aux) with Blue Sea ML-ACR and GM charging diode
  • All electrical components are Blue Sea for distribution and Victron for control (Victron Smart Shunt, Smart Solar MPPT, Phoenix Inverter, and BlueSmart AC-DC charger)
  • AT Overland Atlas topper w/ Truma VarioHeat propane forced air heater, Maxxair fan, 3M Thinsulate thermal liner, Rhino Rack 270 Awning, Diode Dynamics LED RGBW strip lighting
  • 200W of Flexible solar panels on top
  • DECKED drawers
  • ARB Zero 63 Qt Fridge
  • Llumar Pinnacle and AirBlue tint
  • Fully insulated interior with 80 mil CLD and 3M Thinsulate
  • Full stereo w/ Kenwood Excelon Reference DNR1007XR headunit, Kicker KEY200.4 amp, Kenwood Excelon 7" Components up front and Hertz Dieci coax in rear, with Kicker hideaway 10" subwoofer
  • Icom IC-2730A dual band radio, Uniden SDS200 scanner, weBoost Drive Reach OTR, and Teltonika LTE Wi-Fi Router
  • ICS Dash Mount
  • Added USB chargers all over the place
  • Trans cooler upgrade
  • All OEM SR black dash trim and door handles
  • AJT black out kit including steering wheel pieces and key
  • Seat covers, seat heaters, and passenger side lumbar included (not installed)
There's more that is on a PDF list upon request. Will have a fresh oil service with Motul synthetic (all gear oil was changed to AMSoil recently), TRD air/oil filters, etc. before sale. The only "bad" that I can think of is a chip in the windshield that hasn't yet been filled.
Vehicle is located in Hanover, MD and has clear/clean title in hand.
More photos after it's detailed/cleaned thoroughly
$60,000
ThePartyWagon
Nice truck, I found this one on Instagram a while back while researching Tundras as a platform for the Atlas. This is my ideal build for an Atlas. I can't afford it but it seems reasonably priced for what you're getting. GLWS.
anand
Nice looking rig you got there mate. Did you do all the mods to your truck?
Suspension/fuel tank/snorkel/flares and some of the maintenance has all been done at Apex Overland in Reidsville, NC; the topper was installed at AT Overland in Prescott, AZ; everything else was done by me.
Nice rig. What kind of range you getting with the 46gallon tank? MPG's?
If you're around 70mph you can get around 12ish; cruising over 80 will yield you around 11 or in the mid 10s depending on winds
vertical.dan
