SOLD -- FS: REDUCED PRICE TO SELL - Overland Solar 60 Watt Portable Solar Panel, MPPT & Adapters
boisefj
Selling my panel as I have too many and use this one the least. Great for Motorbikes and Hiking, In excellent condition, used only a handful of times. Was listed for $330, now Asking $245 plus shipping and PP fee, Local Pickup is an option too.
Text Ty at 208-407-1265 for a quicker response than posting on here.
Great for Cell phones, tablets, GPS, Sat phones, Cameras, rechargeable batteries, rechargeable camp lights and headlamps and much more.
Specs:
* Dimension Folded: 7" x 5" x 3"
* Dimensions Unfolded: 7" x 25"
* Weight: 3.2 lbs.
Features:
* Charges your devices no matter where you are
* Loops on sides of panel allow you to clip it to a backpack or secure it to many items while open and in use or for storage.
* Design is slim, lightweight and compact
* Directly connect to Single USB and or DC 8-18 Volt Outlets Devices
* High efficiency SunPower Cells construction, ensure your devices charge quickly
* Partial shading protection. See notes below.
* Outer material - Rugged Nylon
* Adapter set allows you to charge a variety of portable items (Adapter Set included.)
* This could be used to charge a vehicle battery with the correct adapter or clamp style connector (not included), takes a minimum of 26 Watt to charge a vehicle battery.
The Overland Solar 60 Watt Ruck Portable Solar Charger is a part of the Ranger Series. The Ruck packs big power for portable phones, tablets, and electronics in a tiny package. Plan on packing this lightweight and compact Portable Solar Charger for all your backpacking, paddling and camping trips. This product packs plenty of power. Thanks to the new SunPower Cells construction. The Overland Solar 60 Watt Ruck measures only 7" x 5" x 3" when closed and weighing only 3.2 pounds. With a Single USB and DC 8-18 Volt Outlet, the Ruck gives you plenty of options for power on any adventure. No need to be left in the dark at night or not totally charger with your devices, the 60 Watt Ruck Portable Solar Charger has the endless power for all your adventures.
Not All Solar is Created Equal!
There are many types and brands on the market to choose from, some at much lower or higher costs. Ultimately, the value of a system is only measured by the amps into your battery. With the most efficient and shade-resistant cells on the market combined with our high-quality charge controller and wiring, our systems offer the best value - more power, smaller size, and longest life.
The silver lining came with SunPower. Based out of the Silicon Valley, SunPower leads the solar world in engineering and innovation with more than 200 patents. The cells perform better in high temperatures and there are no lines connecting cells that block sunlight.One of the most impressive aspects of our new panels is the efficiency even when partially shaded. Shading has always been the enemy of solar panels. When even a single cell on a conventional panel is shaded, the rest of the cells down the line nearly shut down. With our panels, only the covered cell shuts down.
WonaWarrior
