SOLD- M416 - Offroad / Overlanding Setup - $10,000 OBRO
unleashd
This is a completely custom built overlanding/camping trailer. The base was a M416. I bought this setup, as you see it, with the intention of a cross country trip to Alaska. But life happens, and this trip will need to wait a few more years. Here are the details of the trailer. Price is $10,000 OBRO.
  • M416 with a VA Title & registration!
  • Dexter 3500# axle.
  • 6 lug hubs.
  • Ready for ebrakes.
  • 3 Hub centric Spidertrax Wheel Spacers.
  • 295/70/17 Cooper STT PROs. They are probably are good for another 10-15k miles
  • Set of 3 (6 lug) FJ/4Runner wheels.
  • Rear Offset angled spare mount.
  • Sand blasted bed and frame.
  • Black Raptor Liner top to bottom in and out all around. Needs some touch up
  • Extended frame with Open end front hitch.
  • Lunette receiver for pintle hitch, OR Lock-n-roll hitch. Both included in sale.
  • Rear hitch
  • 7 Point jack pipe mounts.
  • 4 stabilizers with socket nuts 19mm.
  • Wired For 7 pin.
  • Split 2 to 3 CURT brake/tail/turn lights kit for quad braking plus left independent turn signals.
  • Lid w/dual gas struts angled specifically for easy open/easy close.
  • Lid safety lock hidden ready for padlock.
  • Interior LED (2) light strips.
  • Lid dedicated 7 pin distribution box.
  • Lid interior wired for a 12 Volt fridge w/30amp fused cigarette socket.
  • HD Roof rack.
  • 360° light pods all around.
  • Backup led square pods (low wattage) for factory backup.
  • Golddog Kaibab Extended RTT USA MADE! ?? Built by a VET!
  • RTT annex room with floor kit.
  • 8ft awning.
  • ARB Room 8x8 ft with floor kit.
  • 8 ft x 8 ft ARB mosquito room included.
  • 100 Watt Renogy Monocrystaline Solar Panel.
  • Wanderer 30 amp solar panel controller.
  • Tongue box with USB ports, 120 volt Male/Female ports.
  • Dual Batteries with boxes and straps.
  • All weather proof/Silicone sealed for leak/water issues.
  • Main kill switch.
  • Bypass switch for vehicles 2nd battery/alt charge.
  • Bypass switch for on board dual battery trailers battery isolation.
  • Trailer fuse/terminal distribution block. Hot and neutral!
  • Ready for e-brake wiring from the distribution (1wire) point.
  • Dual side water tight ammo cans fitted and bolted for storage.
  • Dual 20 lb propane tanks with mounts and cover.
  • ARB Elements Fridge with custom breathable cover for transport.
  • ARB bluetooth on board for remote temperature monitoring.
For full asking price, I will also include the following)
  • Hub conversion kit to 5x150 (Toyota Tundra/Land Cruiser spec)
  • 5 x Toyota Tundra wheels (New take off from a Tundra) with tires (same wheels as in LX470 in pictures)
bvuong
Are you willing to sell just the trailer only? I have a RTT, Awning and Fridge already. If so how much? Where are you located?
unleashd
I live in Herndon, VA.
Ideally I’d like to sell it as a package. Please check back after a couple of months. If it doesn’t sell, I’ll consider your request.
eclipse179
