Dogpilot
Located in Flagstaff, will ship.
$65
Used MSR WhisperLite international 600 multi-fuel stove w/ 22 oz fuel bottle, windscreen and storage bag in good condition.* Everything is clean and good working condition.* Extended Maintenance kit with a full set of replacement parts, everything, springs, valves pump parts check valve strainer. Maintenance kit instructions and stove instructions included.
Manufacturer blurb:
Redesigned for a lighter trail weight, the MSR WhisperLite International represents the gold standard for multi-fuel stoves.
* * Aluminum mixer tube and stainless steel legs reduce trail weight by 10%
* * Able to burn white gas, kerosene, and unleaded auto fuel
* * Perfect choice for globetrotting backpackers seeking lightweight and compact multi-fuel versatility
* * Shaker Jet technology and smart engineering allows complete cleaning and maintenance in the field
* * Folds small and packs into most MSR pots
* * Simple, durable design with over 20 years of proven performance in the field
* * Package includes: Fuel pump, windscreen, heat reflector, small-parts kit, instructions, and stuff sack (Fuel bottle not included)
* * Country of Origin: USA
* * Best For: Backpacking, Mountaineering
* * Fuel Type: Liquid Fuel
* * Weight Range: <1 lb.
* * Ignition Method: Manual
* * Priming: Yes
* * Boil Time: 3.5 min. (White Gas)/4.4 min. (Kerosene) per 1L of water
* * Burn Time: 110 min. (White Gas)/ 155 min. (Kerosene) per 20 oz. Fuel Bottle
* * Type: Liquid Fuel
* * Weight: 10.9 oz.
* * Windscreen Included: Yes
$65
Manufacturer blurb:
* * Priming: Yes
