etherbunny
SALE PENDING 2016 XVENTURE XV-2 off-road trailer from Schutt Industries
Price: $16,999
Mileage: Approx 9,000 miles; Mostly paved and forest service roads.
Great set up allows you to set up camp, then disconnect and go explore.
Description and Specifications:
Base Trailer plus Schutt’s fully loaded “Deluxe Plus” package. (new $34,500. Not including tent and other items listed below)
Price: $16,999
- Length: 156” (incl. tongue)
- Width: 79” fender-to-fender (75” track)
- Cargo bed interior:
- 59”W (49” between wheel wells)
- 89”L (minus 6” for folding galley table)
- 19”H to bottom of closed tonneau cover
- Up to 56”H from bed floor to bottom of rack when elevated and tonneau cover folded/removed
- Ground clearance: 14.25”
- Suspension: 3,500-lb. Dexter independent rubber torsion axle
- GVWR: 3,500 lbs. (dry weight in current configuration probably in 1,300–1,500-lb. range)
- Tires: 35" BFGoodrich T/A KO2 tires
- Wheels: AEV 17" Borah 5-lug wheels that fit Jeep JK and JL hubs
- Hitch: Lock and Roll hitch, including car side with standard 2" hitch
- 7-pin connection
- Electric brakes and emergency breakaway system
- Independent mechanical parking brakes
- Rear 2” hitch receiver
- Two recovery points at rear
- D-rings at each corner allow the trailer to be airlifted in a pinch
- Tent
- Dealer-installed James Baroud Grand Raid XXL hard shell tent (new $5952) in black
- Tent has been professionally coated with ceramic coat to prolong fiberglass life
- Tent is in excellent condition. Have put less than a dozen nights in this new tent since upgrading from my previous JB tent
- Includes Isothermic winter liner kit (never used; new $565), spare mattress (new $300)
- JB Comfort Pad XXL (new $405)
- JB Universal Tablet Holder (new $65)
- Size (open): 63.75”W x 89”L x 40”H
- Size (closed): 63.75”W x 89”L x 13.2”H
- Comfortably sleeps two adults and a child or dog
- Non-smoker
- Sliding ladder, plus one spare ladder
- Galley / Cooking / Water
- ARB fridge/freezer with tie-down kit and optional insulating cover (50Q; DC/AC compatible)
- ARB wireless fridge monitor
- Upgraded galley table with diamond plate, mounts on driver side, with cutout for sink. Upgraded under-rack mounting bracket makes setting-up and breaking-down the galley a breeze
- Galley hot/cold faucet (included) mounts on fender
- Brackets for three 10# propane tanks with two tanks included. Custom bracket right by galley for easy stove hookup.
- Propane system plumbed through body/frame
- Water heater with factory-optional shield with rhino liner coating **see note at end of listing**
- 22-gallon potable water tank; system plumbed through body/frame
- Hand-held shower connection on passenger side near RTT ladder
- Electrical
- Dual Odyssey batteries with custom battery rack
- NOCO Genius Gen 2 20A on-board dual battery charger
- Overland Solar SAE port with solar charge controller
- Zamp Power 1000W Pure Sine Inverter
- 12-volt sockets in battery compartment, fridge, and near tailgate
- 360 deg area Lighting system: lights on all 4 sides of trailer, plus underside ground and bed lighting
- Additional towing 4-pin hookup at rear
- General
- Rhino Rack Pioneer Platform elevating rack system (grants additional 6” clearance)
- Gas strut-assisted elevation
- Hard rolling & locking tonneau cover
- Line-X liner on tongue box, fenders, bed
- Custom wrap in graphite with topographical lines
- Other Included Accessories
- Trailer Jack with a spare handle
- Manuals
- Hi-lift and jerry can brackets mounted to passenger side
- Dealer-installed rear support brackets to add stability to the frame. This is an item that now comes stock on new versions.
- Annual winterization of the water tank to ensure cleanliness
- Used to have an EZ-Awn 270 deg foxwing awning installed, but I have since moved it to my vehicle. Tent configuration on the rack remains unchanged, so it would be very easy to reinstall an awning of your choice.
- The water heater is having trouble igniting. New batteries did not help. Not sure if it is the ignitor or if the unit needs to be replaced. They are approx $180 new, so I will knock $250 off the price to cover purchase and install of a new heater.
- This company started out as a military contract for super-tough trailers. This thing is built very well!
