SOLD!!!Propex HS200 Tent Heater Setup
spressomon
Is the HS2000 enough BTU output to heat a 10'x10' canvas tent (Kodiak) when ambient air temp is 25-35ºF? Was thinking of a larger BTU Espar (had a Webasto in my former Kimberley Kamper ...) but like the idea of propane instead of diesel.
Happykamper
Never have seen Martyn in this light before, attacking a person who one offed something using ideas he gleamed from the forum. I just have to ask is AT that threatened by this one heater that they would show there a-- to the world. I have a chaser and a Horizon. While I did not buy from AT I still am asked questions all the time about them, and I have given very positive reviews, mostly because I have received great customer service from them from time to time. I have also bought some high priced but very capable gear from the shop.
I really don't think a Mod needs to step in, what I believe needs to happen is just a plain and simple apology. Martyn I have met you on a few occasions and you seem to be a very good person. We all make mistakes , God knows I've stepped in it quite a bit, but I believe if you look at this you will do what's right and give the man an apology. My .02
Martyn
Yes guys you are right, that was harsh of me. Lots going on in my life right now, after a couple of glasses of wine last night I was pissed off. I usually bite my tongue but I didn't this time.
mellorrob
I used my HS2000 in my 10X10 Kodiak with the outside temp at 25 degrees and it kept the tent at 55 degreese running all night. I did have the return hose plumbed into the tent so the heater was recirculating the warm air. More BTU's would have been better but it was totaly fine with a decent bag and I didn't have to have my head burried in the bag to stay warm. That's kind of a big tent for a smallish heater, but I was impressed it could maintain a 25 degree difference. If I was going to be winter camping in those temps alot in the Kodiak I would try stretching a tarp over the top for a fly like the Eezi Awn and other RTT have, might help with heat loss. In the Eezi Awn 1200 it can cook you out of that little tent if you have the thermostat turned up too high.
spressomon
You confirmed I would like to have the larger BTU model HS2800 (when it is: Cold, windy and higher elevations). Thank you for your input!
Chris Boyd
Not to hijack the thread, but does running heat in the various tents cause any issues with condensation? I have an Oztent RV that has been noted to have some inside condensation issues if the top vents aren't open. I wouldn't want to open those vents, since heat rises and the vents are at that peak. If anything I would assume the heat would cause heavy condensation on the outside?
Free bump, GLWS!
pugslyyy
Free bump, GLWS!
Having good airflow is always key to avoiding condensation (and not going crazy with the amount of heat you use). I just always figure on having a high vent open. When in the camper I keep a roof vent cracked open, when in the van I keep the front door windows 1/4 inch open. Tents I've used always have a mesh vent at the apex - with the tent it is more an issue of getting condensation inside the rain fly.
spressomon
Another advantage to this type of heater: You don't have the propane flame source inside the vessel. Propane (and NG) contributes considerable water vapor.
dhuss
