More images located here:
Turn key Camper Van with Low Miles - rvs - by owner - vehicle...
2007 Ford E350 Chassis with a Supreme Corp. 7ftx10ft Box 65k original miles All components/build...
denver.craigslist.org
65k original miles
Asking $30,000 OBO. Clean and clear title in hand. I’ll accept cashiers check from your bank, or cash.
All components/build out/upgrades have been done within the past year with brand new components and have less than 3,000 miles on them.
Van was built out to be a multipurpose adventure rig. We built and used this van to chase fresh powder and sweet mountain bike trails all over Colorado. As such, we made sure it functioned equally as well in the summer months as in the winter months fully off grid. This was considered when designing the electrical and plumbing systems, as well as the layout configuration. We sought out a short box van with a single rear wheel to convert as it allows for a queen size bed to be installed across the back, while keeping overall vehicle length and width to a minimum, and thus maneuverability to a maximum. It easily fits into any size parking space, and into most drive throughs (under 9ft total height).
Reason for sale: We love this rig but are looking to buy a house and could use the cash for a down payment.
Note: Some personal items included in pictures will be removed from van before sale.
Please read entire ad before contacting me with questions. If you see the ad, this is still available for sale.
Van is able to be insured as an RV, lowering costs of ownership.
Van will be sold with full fuel tanks, water tanks, and propane tanks. Add clothes and food and tour the country.
Denver Airport meetup can be arranged for serious parties looking to fly in and purchase the vehicle.
Full details below.
Drivetrain
5.4 liter V8
5r110 5 speed Automatic Transmission w/Tow Haul Mode
4.10 gears with limited slip
65k original miles
32+ gallon fuel tank (Most I’ve ever put in was 32.5 gallons)
Hitch rating of 700lbs tongue weight, 7,000lbs overall weight
Van was originally a Texas vehicle-completely rust free, super CLEAN undercarriage
Van is 2wd. We purchased with the intent of converting it to 4x4, and it is an excellent candidate for a conversion. The chassis cab is much easier to convert than a traditional van as you don’t have to modify the fuel tank or exhaust, etc. However, after our use of the van we quickly figured out there was absolutely zero need for 4x4. We have taken this thing through mountain passes with snow absolutely dumping (some epic powder days up in Steamboat this year…) and on some rough, muddy, and rocky forest service roads and trails with zero wheel slippage. With a lot of well distributed weight over the rear axle, good tires, and the limited slip rear axle, we decided there was no need for a 4x4 conversion as it will literally go anywhere we have wanted with ease. If you decide you have to have 4x4, conversions can be done by many shops for between $12-15k. Buy this for $30k, have the conversion done, and still net out better than any sportsmobile for sale today.
Suspension Upgrades
Bilstein 5100 series Comfort shocks all 4 corners
Moog c880s progressive coil springs providing 1” of leveling and a much smoother ride
Steering stabilizer setup from an e450/ambulance package using Ford components
Wheels/Tires
Aftermarket aluminum wheels
265/75r16 (32”) Falken Wildpeak AT3W LR E All Terrain tires with 95% tread remaining. Tires are 3 peak mud/snow rated.
Other
New Front receiver hitch
New LED lights all around including Headlights, Taillights, and Reverse lights
Front bumper, rear bumper, and grill repainted with bed liner
Front window visors-keep the rain/snow out while still getting airflow
Build Out/Amenities
Fully insulated-Roof, walls, floor
Sound deadener installed on roof and cab floor
TONS of storage
Lipert RV Side door with screen door
Queen size 6” foam tri-folding mattress-this is honestly comfier than the mattress in our house
Bed platform built high enough to house mountain bikes underneath.
Bed platform easily removable and mattress storage bag included allowing van to serve as a motorcycle, atv, snowmobile, toy hauler.
Two Kuat Dirtbag boost bike fork mounts included for under bed bike storage
Full Kitchenette: flush mount 2 burner propane stove, slide out 65qt YETI cooler, Foot pump sink
Water storage uses 6 gallon water cans to allow for ease of refilling anywhere and full winter operation without anything freezing up. Van will be sold with 3 cans-1 is currently used as grey water from the sink drain and two additional used for fresh water.
Portable Flushing Toilet-Porta Potti 365
LED lighting with dimmer switch
12v Charging center with cigarette lighter socket, 2x USB charging ports, and Battery bank voltmeter
MaxxAir MaxxFan Deluxe with 10 speed intake or exhaust with integrated rain shield
Rear auxiliary Air Conditioner and Heater that run when the vehicle is running
Olympian Wave 6 catalytic propane heater with quick disconnect hose and cover
Propane Alarm
Carbon Monoxide Alarm
Fire Extinguisher
Electrical System
System designed as serious overkill, but also able to accommodate any future upgrades such as inverter, 12v fridge, etc. You’ll never run out of power.
Twin 100ah batteries in parallel providing a total of 200ah battery bank
Blue Sea fuse block
140 amp battery isolator-allows batteries to be charged off the alternator anytime the vehicle is running-No need for expensive and finnicky solar panels that you have to clean off in the winter
NOCO Genius Gen 2 20 amp charger for running off of 120V power (only used when stored for long periods to maintain batteries-the isolator keeps them fully charged when the van is in use)
Exterior 120V hookup
