SOLD
Wfu077211
1 View attachment 672572This adventure RV MBS Sprinter 3500 is immaculate and I purchased it brand new and it has only been used a handful of times. This compact, yet spacious ride is fully-loaded and self-contained. Ready for off-grid living or reliable, luxury travel coast to coast. The most impressive aspect is the Blue TECH turbocharged diesel with less than 20,000 miles. This RV handles and drives like a quality SUV, yet offers plenty of space and options. There is exceptional ground clearance and it comes in at just under 24 feet in length. Sleeps 6 with ample storage inside and out. The bathroom and shower is wonderful as is the premium queen bed. What's really nice is the dining table and bathroom can be accessed without the slide being out. The two coach deep cycle batteries are less than a year old as well the Mercedes driving battery. The unit is Zamp plug and play solar ready. There is an outdoor propane quick release adapter on the right side rear with a portable grill. No need to worry about carb cleans on the onboard Onan propane generator that is super quiet and efficient. Want to live year-round in it, the Arctic Package keeps the tanks from freezing, the heat pump allows for additional gas or electric heat and the block foam keeps the unit well insulated. Need to pull a trailer, no problem with the Premium Camping Package that includes a Class III Receiver. Don't forget the outside shower and sound system. The Mercedes Sprinter chassis with the Helwig anti-sway system makes this unit driveable in high wind conditions. I am open to reasonable offers Kim Wallace 503-930-4294. If you do your homework you won't find a better deal on this type of adventure RV. In fact, here is the name and contact info of Woodard Mobile RV in Salem, OR who has meticulously cared for this unit Bob Woodard cell# 503-713-8359 or office# 503-341-5868 email mobile@woodardrv.com.
Adventure ready with:
  • Brand new heavy-duty off-road tires
  • New weather tech matts
  • New weather tech seat covers
  • Recently detailed and professionally waxed (receipts included)
  • Brand new bumper to bumper exterior compartment seals
  • Recent Mercedes full-service (all receipts included)
  • Battery disconnect switch
  • Water heater bypass
  • (2) new deep cycle coach batteries
  • “Easy Access” battery in step-well
  • 30/50 Amp service with power cord and adapters
  • 60 Amp Progressive Dynamics converter
  • 6 Gallon DSI gas/electric water heater
  • 30,000 BTU furnace
  • Satellite/cable connection
  • 13,500 BTU ceiling ducted roof air
  • 3.6 KW Onan LP generator (propane)
  • Automatic generator transfer switch
  • Water filtration system
  • Upgraded shower head
  • Arctic Package (12V tank heaters)
  • 15K BTU A/C with heat pump
  • Carbon Monoxide, LP and smoke detector
  • Winegard digital antenna
  • 1.5” Aluminum framed laminated sidewalls
  • Superlite composite substrate
  • Gel Coat exterior fiberglass
  • Block foam insulation
  • Power patio awning with LED lights
  • Slide-out awnings
  • Fiberglass roof
  • One-piece fiberglass front cap
  • LED exterior lights
  • Stainless steel wheel liners
  • Valve stem extensions
  • Roto-cast storage compartments
  • Driver side security light
  • Fiberglass running boards
  • 110V, GFI protected exterior receptacle
  • Tinted frameless windows
  • Heated, remote exterior mirrors
  • 4,200 Lbs. hitch, 7-pin connector
  • Roof ladder
  • Power entry step with motion sensor light
  • Stabilizer jacks (2-point)
  • LP quick connect
  • Full body paint
  • Outside shower
  • Outside 12V LED TV
  • Black tank flush
  • Fresh water 35 gallons
  • Gray water 32 gallons
  • Black water 32 gallons
  • Added protection with EcoRV treatment--ExteriorShield and MicrobeRepel
  • Platinum Coverage Extended Warranty.
I am asking $94,500 and located in Salem, OR. There is Platinum level coverage from American Guardian Group until 3/2024 that includes convenience package, unlimited towing, audio / video technology, Engine, transmission, drive axle, suspension, steering, ac, fuel delivery, brakes, electrical (chassis), electronic technology, frame, interior/exterior hinges latches etc., seals and gaskets, wear and tear, water heater, fresh water, sanitation, ac, range and oven, LP Gas, heating, refrigerator and freezer and generator. This extended warranty is transferable to the new owner and worth over $10k for this level of coverage. You can't touch one of these for under $125,000 new, plus the cost of the extended warranty, if you can even find one right now with the diesel. I will also include a new portable propane fire pit and cover, outdoor matt, extra leveling blocks, sidewinder sewer hose and any interior organizers.
The price is not inflated based on market conditions—I simply cannot handle this unit by myself and have had health issues.
Must see to appreciate!
Thank you for your interest,
Kim
nahuebsch
