The Yellow top charges fast, in only 45 minutes it was at 13.6v.
That's called a "surface charge". It means that the voltage is up, but the chemistry is not fully activated (stirred up) so the voltage will drop faster than if it was *actually* fully charged.
This is why a 3-stage charger (like the SSD) will "bulk" the battery up to a higher voltage - usually 14.4v, though some go to 14.6v or 14.7v - and then drop down to usually 14.2v and hold it there.
When it drops to 14.2v and holds there for a while, that's called the "absorb" stage. It does that in order to let the chemistry in the battery fully absorb all it can. It'll stay in absorb until the flow into the battery drops to less than 1 amp.*
Only THEN is the battery TRULY "fully charged". It just can't absorb any more.
And then it drops to float and holds at usually 13.6v or 13.2v depending on who made the charger.
* For most chargers - the Iota IQ/4 module will run a timer and not stay in absorb longer than 8 hours no matter what. After 7 days at float, another timer trips and it start sover and does a quick run-through of the bulk and absorb stages before dropping to float again.
Progressive Dynamics' units also have a timer - after 48 hours (IIRC) at float the timer will trip and they'll kick up to a higher voltage for 15 minutes.
Some chargers will drop out of absorb when the flow is less than 2 amps.
Also a quick note on installing the SSD:
Run dedicated +/- wire to the batteries. DON'T just run the negative to the frame of the truck.
The reason is, that a PWM controller can switch the power on/off to the battery hundreds of times per second - and that rapid switching can cause noise that shows up as radio interference.
Running the negative to the frame would work fine, but it could end up creating some noise in radios or amplifiers.
Also, keep the +/- wires together - actually, twisted together is best but not really needed for 12v stuff - the further they are separated from each other, the higher the chance of EM noise.
