Soooo....I got stuck! Any recovery advice?
DiscoDavis
it doubles the pulling power of a winch or hand winch, same principle as a pulley making it easier to lift a load.
Instead of anchoring to a tree with the winch line, the winch line goes through the snatch block attached to said tree and doubles back to the vehicle and secured.
https://www.youtube.com/watch?v=OXxLh8shMu8 He's got some great videos, all around good guy to watch.
Silmarillion
Just watched that video! Thanks. How do you anchor it if you are using a come along? These all seem to have the starting vehicle with the built in winch.
What other recovery point is there in the front/back of the LR3 besides the trailer hitch loop and the sump pump area recovery point up front? Looks like the double line tow requires two recovery points on the vehicle?
Ok, thinking this through, you attach the snatch block to the LR3's recovery point?
donaldcon
Looks barely stuck to me. Hook a strap to another vehicle behind it, put it in reverse and let them pull it out.
Silmarillion
The short quick answer is get a big tractor for this situation. After the tractor arrives the danger starts.
The long answer is get to a certified 4X4 driving class. I do not say this in jest, but a I4WDTA educator is worth more then all of the equipment you can buy. Buying equipment should be second and not first. For this situation you are a little late. You can buy enough equipment and overload your vehicle that your vehicle can not be able to move out of the driveway. That will cause more problems then the equipment will be able to help you get out of.
Once you have equipment, then knowing how to use it properly in the next big step. Using it wrong can make things worse or even worse when a person is hurt or killed.
So dose any of this help for this situation NO! So why the lecture if you want to consider it that way and who am I to say this? So I have 45 years experience of 4-wheeling, I have 25 years as a 4X4 educator, I am a I4WDTA educator (and one of the founders of the I4WDTA) and owner of Western Adventures 4X4 Driving School (now retired).
I could answer my thoughts of this vehicle recovery and what I would do, but you have got some already. There are additional considerations that I would need to be at the site to look at before giving a refined set of instructions. I also will not type out a 8 hour class of recovery instructions.
When you get the vehicle out check for a I4WDTA instructor/educator in your area for instruction. This will be a better investment then any product you will buy! Then buy what you really need and not just stuff to make your vehicle look cool!
We did try that. First vehicle wasn't getting enough traction - check the video link posted earlier.
mpinco
Yup
Longer kinetic strap, blanket/rug to dampen strap failures, shovels to remove mud damns created, align steering, get-er-done.
DiscoDavis
If the stuck vehicle is the one being pulled (you have no winch), the snatch block would be attached to the front recovery point. The come along/hilift/winch would be attached to a tree or other vehicle as an anchor. There are no other recovery points on the D3 as far as I am aware. The double line tow does not require two points, you see Ronny do it like he did because he is winching himself. The snatch block he is using for the double line pull is only anchored to one thing, the treesaver/tree.
LR Max
Local Oaf
Hi-lift jacks do nothing but scare the crap out of everyone involved. A bottle jack or the stock jack can accomplish the same thing easier and safer.
I echo what was said earlier. You don't look too bad stuck, and the entire truck was rocking back and forth. If the cruiser gave it a bit more oomph, he probably could have pulled you out.
Kevin108
Are you sure you know what a Hi-Lift is? A bottle jack cannot be used as a come-along. A bottle jack cannot reach up to 60" heights. A bottle jack is just as heavy as a Hi-Lift. Maybe you just need someone to show you how to use one.
Kmrtnsn
Hi-lift jacks do nothing but scare the crap out of everyone involved. A bottle jack or the stock jack can accomplish the same thing easier and safer.......
Clearly you don't come from that time when EVERY car and truck had a jack that functioned just like a Hi-Lift. It's an ********** tool for Christ's sake, it is not imbued with mystical qualities, it is not alive, and it is not inherently evil. Good luck getting your rig unstuck with a bottle jack.
DiscoDavis
Yeah x2. This is the third or fourth time someone wandered into the thread and heard hilift, only to keep talking about using it as a JACK. What has been suggested (and justly so) is using the hilift as a winching device... Read the thread people :ylsmoke:
NatersXJ6
Another HI-Lift Use
Heh, heh...
When I was in college, mud was frequent when wheelin. We would occasionally (commonly) lift one end of a vehicle with a hi-lift and then push it over sideways so it fell off the jack and out of the ruts. Repeat at other end and then drive away.
As a fair point, we made sure bystanders were clear and not many of us had rigs nice enough to worry about body damage.
That was my first thought when I saw your pictures.
Clemtiger84
