I think I figured out what the previoius owner attempted to do with the antenna setup --- http://www.firestik.com/Tech_Docs/SNGL-or-Dual.htm
There was one mount on the front bumper and one on the rear tire carrier. The vehicle is a mix of aluminum and steel, steel roof, steel passenger doors, aluminum front and rear quater panels, aluminum hood and rear door. So the ground plane is pretty bad!
Using the two mounts he may have been attempting to rig a co-phased antenna which requires RG-59 cable to be used. The front mount had RG-59 cable running to the radio wher it joined the other cable in a joiner plug that went to the radio. The problem I see was that the cable going to the rear mount was RG-58 and it had two very bad hand wound splices in it. This system would have requred him to have two antennas installed at all times!
DaveInDenver said:One reason people try to splice coax is to feed two antennas from one source. There are probably correct ways to build a harness to do that, but other than truckers with their CBs I'm not personally aware of anyone who does that (other than commercial broadcasters, but that's a little more sophisticated). It's hard enough optimally tuning a single antenna, forget dealing with two radiators! With co-phased antennas you need to be super careful about the distance between the two whips and it'll really only works well at a relatively narrow bandwidth. The two whips probably should not be flopping around in the wind, either...
