luthj
Engineer In Residence
Got it mostly together. Far enough to measure the backlash at least. If I am measuring it correctly, its 20 thousands at the yoke, which is 10 actual. spec is 6-10 without me messing with the adjusters. Which makes sense, it was higher before due to the failed bearing, and I am using the same gears and pinion bearings. I will check the contact pattern over the weekend. The lockers air transfer collar makes it annoying to assemble, as once you put the right case half on, you really can't take the diff out of that half again, at least not easily. They also use 2 tiny O-rings to seal the bulkhead fitting. They are very difficult to fit over the end of the copper tube. So I needed to chamfer the tube, and slightly enlarge the brass spacers ID.
Here is the failed bearing outer race.
