Sprinter 4WD Conversion Idea, GMT-800 IFS.
luthj
Engineer In Residence
There are different versions of the wheels (standard/metric)? Whats the break years? Do you happen to know the offset off hand?
Len.Barron
I've never looked up what the backspacing is, it has to be a pretty good amount because on the 4wd F250's the lockouts stuck way out past the tire bulge and guys would shear them off on tree stumps..
luthj
A good look at the photos shows those wheels are probably pretty similar offset to the factory GM wheels. I will send the guy an email so see if he can measure the backspace for me.
Vandit
Nice choice on the tires. I put those on my truck a little while back and I've been very happy with them thus far.
You're getting close!
luthj
Finally back on the ground. Track width is right at 69" with GMT800 standard wheels. Its riding a bit high, I expect it to settle an inch or two once I cycle the suspension a few times. Camber adjustment is going to be right at the limit of the upper slots. In future revisions I may need to adjust the LCA out 1/4".
V45W_Proto2.5
