mountainhick
I went with 5 hole factory steels in black. No plastic cover. I will probably use chrome capped lugs and paint the hub black to match.
View attachment 581345![]()
Steel Wheel, Rim 16x6.5 - 5195
Transwheel Steel Wheel, Rim 16x6.5, 8x6.5 Bolt Pattern, 5 Spoke - 5195www.wheelstiresandmore.com
Thanks.
Those are the ones (at least look the same as OEM) you rejected last July because backspace was too deep. Oh well, live and learn. I can probably get 6 at the junk yard and finagle selling the other ones I pulled then which have less backspace.
Will you do me the honor of measuring the actual backspace when you get them? Looks like they are aftermarket, not OEM according to the website info. May be some difference.
Thanks
