pawleyk
Running from Monday..
MERCEDES SPRINTER DUAL ALTERNATOR KIT WITH 280XP AMP ALTERNATOR (2014-2017 WITH 2.1L) This is how you get BIG power into large lithium power banks.. this alternator will supply 280 DC AMPS at just off of idle. Includes Balmar Regulator programmed for Battleborn lithium batteries. Complete kit, brand new, never installed, still in box.. Local Pickup preferred, but I can arrange shipping as well. Retail $2349.90 before shipping or tax.
Asking $1850.
From Nations' website: What does your dual alternator kit come with? Complete Dual Alternator mounting bracket and parts with complete Installation Instructions 280XP High Amp Alternator OEM High Quality Mercedes Parts Runs Alternator with approved Mercedes Benz parts Reliability tested in field for years You can add a External Regulator to your package to gain more optimal performance.
Note: If you are using Lithium Batteries, this is a requirement
Why run dual alternators? What if you had a separate charging system dedicated to the additional accessory load? By running dual alternators you can do just such a thing, and doing so leaves the factory charging system intact doing what it was intended to do, running the vehicle while the secondary alternator carries the additional accessory load. By effectively doubling the available amperage of the vehicle, you can run more accessories with less worry, and all for about the same cost as a single high quality High Output alternator. We are very proud to say, this dual alternator kit is 100% designed and manufactured in the USA! The Technology Our XP series high-output alternators are the ultimate upgrade when you need the absolute biggest and most sophisticated high output alternator on the planet. All of our XP series alternators are designed for one purpose, brute force idle output. When you need the most extreme idle output with the most sophisticated integrated alternator-monitoring system to prevent thermal failures is where the XP alternator delivers. Every Nations product we sell is held to the strictest quality standards in the industry. We only use 100% brand new USA made components along with one of the most rigorous testing before each individual alternator leaves our shop. Each XP series alternator comes standard with our decoupler style pulley and 2-year replacement warranty. If you're looking for a significant overall increase in top end and idle output, the XP series alternator is your solution.
Asking $1850.
