SkiFreak
Crazy Person
Happy to here that you found my website useful.
I had not realized that your subframe was made from aluminium (or aluminum, for those of you in the other half of the world); I thought it was zinc plated steel. Knowing this now, might I suggest some strengthening plates on the inside of the sections (near the chassis step) that only have circumferential butt welds (areas with red circles).
It is not easy to see from the images, but how much clearance do you have between the bottom of your front subframe rail and the top of the air cleaner box?
On my truck I have allowed for 35mm of lift between the chassis rail and the subframe. This equates to about 50mm of movement at the air cleaner. My front rail is behind the nub at the top of the air cleaner, but your rail is directly above it (red arrow). Do you have enough clearance here when your subframe articulates?
