Dolomiti
I picked up a low mileage (110k) 2.5 yesterday about 5 hours from home. Vehicle was in good condition and I did a look over before driving it home.
About 35 miles into the return I encountered an odd problem. I was using cruise control at about 75 mph and had the a/c on high when I glanced down and noticed the temp gauge rising. It was a little below the mid way between normal (middle) and high. As I slowed down, the a/c cut off and the temp stopped rising. I pulled over and all things seemed normal, coolant level fine, coolant cycling through radiator, fan and a/c fan operating normally, belts fine, no leaking fluid, no binding of belt when compressor engaged, etc.
As I started driving again, temp returned to normal, maybe even a little below normal, and a/c began working again. So long as I drove about 65-70 with a/c on econ, temp would remain in mid range but would fluctuate mildly between slightly cooler and slightly warmer. If I slowed down while driving in town, it would cool down. If I turned to a/c or drove faster, temp would rise.
I'm stumped. I made it home fine but have no idea. Engine bay is clean and there are no noticeable leaks around the head. I plan on putting in a new cooling system and timing belt anyway, but this problem seems illogical.
