Subaru Impreza "XV" - Building A Crosstrek / Michigan Adventure
Jack Stilts
Subaru Ambassador
Looking forward to your trip reports, warm weather is just around the corner!
Yes it is! Been enjoying this very mild Michigan winter.
I have phase 1 of mission "go outside" complete - my new Thule roof box is in. Replaced my Force L box with a Pulse Alpine in order to house my new Oz tent RV3. Turns out I did my math pretty well, because it fits in there perfectly. I'm very excited to have everything coming together so well! Phase 2 of mission "go outside" is in progress - I have the full 2" lift kit from ADF on order, along with General Grabber ATs in 205/75R15. Also ran into a very familiar face...
Jack Stilts
Subaru Ambassador
Loving the simple look you have going. Nice build!
Thanks! I'm really enjoying this car.
I have phase 2 of mission "go outside" in progress - just got in 2 of 5 of the General Grabber AT2s in 205/75R15. Waiting for the 2" lift kit from Anderson Design and I'll be good to go! I also started the revamp for my roof rack system - getting rid of the OEM Euro-style bars in favor of a full roof rack system. Got in roof rails today from a Crosstrek, so that will be completed soon!
Jack Stilts
Subaru Ambassador
Had a very productive day with the Impreza! I've had a four-part to-do list for a while now, and I finally did 3 of 4 today:
  • Underbody splash guard - replaced broken / torn plastic.
  • Rear spoiler installation - eBay Wing Tech painted 32J Obsidian Black.
  • Spark plugs replaced - NGK laser iridium SILZKAR7B11 (gapped .39)
The splash guard was ripped off during a fight with a tall parking block, so I found out that it could be replaced for a relatively cheap cost ($40). What I didn't know was that it wasn't just the small triangle of plastic; it was the entire wheel well liner, all connected in one piece! I could not believe the size of the box that showed up on my porch. Anyway, I didn't want to replace the whole liner, so I made the decision to hack it up a bit and bolt / zip-tie it to the remaining liner. It looks like Frankenstein, but it's very functional. Plus, it's not visible unless you're under the car :)
Ah, the rear spoiler. Been wanting this since day one. Every hatch & wagon deserves a spoiler. I was going to get the OEM Impreza Sport (same item as the Crosstrek), but didn't want to shell out the $300+ to get one. I had been watching one on eBay for quite a while and finally just bought it. The company is called Wing Tech, and you have the option of getting a spoiler unpainted or painted. For an extra $80~, they will paint match to your color (have to send them your paint code information). It took about two weeks, which wasn't bad at all, and it is great quality. The paint match is exact to my car, and overall I'm quite pleased with it. The template is different from the Subaru one in that it doesn't come with the big overlay / sheet of paper, but instead comes with four strips of cardboard that line up over the holes in the spoiler. Then those strips are placed down on top of the trunk, and the drilling begins! It was nerve-wracking, but it wasn't my first time drilling into a car. A few years ago, I took a 3" hole saw to the fender of my Xterra for the snorkel installation. Most terrifying thing for a novice tinkerer like me. Anyway, it turned out great. Went on fairly easily, and I love the way it looks.
Spark plugs! The Impreza is currently at 63K miles, so it was time. I've heard varying things about the complexity of this job, but I completed it in an hour with no issues. I keep comparing everything I do to my last vehicle, which was the Xterra. The 6th spark plug on the Xterra, for those of you who are unfamiliar with the 3.3L Nissan engine, requires a 12-16" socket extension, a wobble joint, and lastly requires you to sit on your engine to reach it near the firewall. It's hell. The process was pretty straightforward:
1. Disconnect battery negative and positive. Remove battery (10mm socket).
2. Disconnect coil pack harness.
3. Unbolt coil pack (10mm socket, 12" extension). Remove coil pack.
4. Remove spark plug. Install new spark plug.
5. Replace coil pack, coil pack bolt, and harness. Replace battery but leave disconnected.
1. Remove air box (10mm socket), disconnect MAF sensor.
5. Replace coil pack, coil pack bolt, and harness. Replace air box and reconnect MAF sensor.
Reconnect battery terminals and fire it up. Done.
I'm also very excited to know that the full 2" lift kit from ADF is en route! Can't wait to get this up higher for the GG all-terrains sitting in my garage.
The only other thing I'm working on right now is the roof rail situation. I have the fixed crossbars, and I got a set of Crosstrek roof rails from another member here. I want to remove the fixed Euro bars and install the full roof rails to get adjustable crossbars, but I need some kind of schematic. It's nearly impossible to find one since the Impreza Sports and Crosstreks come with the rails from the factory. Just need to know where to drill and I'll be rolling.
Jack Stilts
Subaru Ambassador
The 2" lift lit from ADF has finally been installed! Took 3 hours and I'm glad it's done. I can finally get these winter tires off. Will be getting the General Grabbers in 205/75R15 mounted this week. I now also have 9.5" of ground clearance!
Rattler
Thornton Melon's Kid
Looks good!
ry3w
Looks great!
Would be interesting to see a side by side with Crosstrek
Sent from my Nexus 6P using Tapatalk
Jack Stilts
Subaru Ambassador
My little C-class economy car is turning into a crossover. It is so strangely tall.
2012 Impreza base hatch
ADF 2" lift kit - 2" front, 2 3/8" rear, multi-link spacers
General Grabber 205/75R15 on stock steelies
No rub at full lock :)
Previous setup was 1" ADF spacer lift on the General winter tires - 205/70R15. The two setups are perfect:
1" spacer lift = 205/70R15
2" full lift = 205/75R15
I planned this out months in advance, and it was all a theory. I had to do math. It was scary. Was very glad to see this work out.
Jack Stilts
Subaru Ambassador
Thanks guys!
I had two camping weekends recently, but neither with the Subaru. Had two great opportunities to play with the new Oz Tent though! I love it. The first few shots are from Michigan, somewhere on state land. A trail ends at a large pond / small lake and I wanted to check it out, so we did! Had a great time, and had the place all to ourselves.
The next trip was Memorial Day (all pictures below are on private property). Growing family = lots of stuff. Enter Transit van! Loaded up way too much stuff - two Power Wheels, tent, dog, toddler, air mattress, archery equipment, firearms, food...man oh man. Definitely took advantage of all the space we had...maybe packed too much stuff. Anyway, it was a great time.
I'm looking forward to some more summer adventures. I feel like I just broke the ice, and that summer will be a great chance to stretch the legs of this little car. I have a few trips planned already - one around Michigan for a few days (might take the Subaru, might take something else) with limited camping, and then the big one - Overland Expo East in October. Going to plan around that weekend and turn it into a little overland trip in the surrounding area.
