Subaru Outback roof rack options
p nut
butter
Needless to say, the stock roof rack sucks on our Outback (newer gen with the folding arms). Yet, there are no options for a replacement. I'm talking replacing the whole thing.
_
Looking at the Landcruiser racks, it seems like if simple towers could be fabricated, rack options would be endless. I'm not sure if it would be as straight forward as the Landcruiser installs, but I wouldn't think it would be too hard. I don't know what lays under the plastic of the current rack, so who knows.
_
Any inputs or any interest in something like this?
http://www.gamiviti.com/installation-tips/
1469504509478
Wondering if we could even get Gamiviti to fab some up, if there is enough of us looking for something like this.
screwball48
I think one of the Prinsu Design racks would look awesome on an outback. Clean and simple with increased strength and capabilities.
MANUCHAO
Aventurero
I been thinking taking the whole thing off and building / designing a low profile made out of aluminum with an integrated fairing to hold a light weight RTT / surfboards....
vicali
Talk to Zach at Prinsu.. the oem rack bolts on there somehow.. check on the outback / off-road Subaru forums as well..
outback97
_
_
I have a 3rd Gen OB, but am considering a purchase of 5th Gen in the future. I normally have a couple of Yakima Frontloaders on my Yakima crossbars and they are very solid. This whole new gen roof rack thing is pretty annoying, sounds like the folding crossbars are flimsy.
Digging around on subaruoutback.org I found this:
http://www.subaruoutback.org/forums...ed-parts-diagram-2015-outback-roof-rails.html
It looks like it's a PITA to remove the stock rack.
p nut
butter
Thanks for the info/inputs.
_
Here is a video found on youtube. Looks like as outback97 said, headliner needs to come out. The guy on there said 1 hr "if you're good." So probably a weekend project for me. After that, it looks to be fairly simple--just unbolt and remove. I'm thinking if I move forward with this, I would tack on some nuts on the inside. Then, I wouldn't have to deal with removing the headliner again. Messing with airbags freaks me out, though...
[video]www.youtube.com/watch?v=6TlkuPXuNnQ[/video]
p nut
butter
http://forums.mtbr.com/car-biker/2017-outback-touring-actual-real-roof-rails-1016218.html
Check out the rack in the first photos of this thread. I know it is not as good as a Prinsu rack would be, but it may be a better base rack for mods than the big plastic one that is common.
Looks like same/similar to Forester racks. It would be nice, but according to a couple of people in that thread, it would cost over $1k for the parts and mounting points would be different for older gen Outbacks. Glad they're finally coming out with this, though. Folding rack was a dumb idea.
_
crfnick56 said:
yea, they are real roof rails that you mount a railgrab type crossbars on. Subaru actually already has a roof rack system with Thule for the Outback touring with these new rails. Subaru part# SOA567x020 if anyone is interested. After assembling our dealerships Thule display a few weeks ago I think I would rather stick with a hitch rack personally. Maybe this new outback roof rail system would change my mind though.
As far as retrofitting the new rails on to the older/standard model Outbacks, I would be willing to be the mounting holes are in different spots and I know just to replace the old style rails you had to drop the headliner and everything so it was a TON of work. Not worth it in my opinion.
XJaredX said:
Yeah, as an example, my dad looked into getting the Forester roof rails to put on his base Forester which didn't have them, and with my employee discount, the rails and all required pieces were still over $1000 (you had to piece together every little nut and bolt) and yeah, drop the headliner and etc etc.
Buddha.
Finally in expo white.
I've got the base forester no roof rails. Theres little caps to pop off with I assume a nut under there to attach subaru's crossbars for cars that didnt have roof rails from factory. I'd like something better though.
p nut
butter
I had the same issues as you with the lousy factory rack and came up with an alternative for mounting standard Yak round bars solidly, that doesn't require removing all the plastic goodies, drilling the roof or any of that jazz. Take a look at my thread here starting at post #84 and see what you think of this option http://www.expeditionportal.com/forum/threads/146548-2015-Subaru-Outback-Expedition-Retrofit/page9
Yeah, I saw your build. Very nice. I want to get something more lower profile, so I'll see where I get with this. I may contact you if that ends up not working out.
So there is a welded nut there? If so, that would solve a lot of headache for you.
jacobconroy
Hillbilly of Leisure
If you ever decided to make up a batch of your custom mounts, I would probably buy a set to try on my 2016. How many inches is it from the top, center of the roof to the top of the round bar? Looks like it is a couple inches lower than my current Yakima/landing pad setup.
Buddha.
I assume there's a nut but I have to check
Edit: I checked. If you pop up the little hinged cover there's a plate there maybe 3/16" thick with two threaded holes., Probably not much of a weight rating for the setup no matter what I do.
midlifecrisis
From the roof to the top of the round bar at the center: 4-1/2" at the rear and 3-3/4" at the front.
I could shorten the pads by ~1/2" and slam the cross bars right down on top of the factory plastic, but it seemed prudent to leave a little bit of clearance there.
Getting everything down as tight as possible was one of the wish-list items I had that got me chasing my own design. I don't like how tall the after-market options are and I hate the way they mount. I love Yakima stuff generally but sometimes I really have to scratch my head at some of their engineering design choices.
Mitch Bears
