Suburban Adventurer
Jacksoneson
Weekend Wanderer
Thanks for the feedback John. The running boards were on the Burb when I got her. I think they are a generic bolt-on from the 90's. Not really rock-protection, but great for standing on to reach the cargo rack. They bolt to the body pinch-weld and are braced to the frame rail with clamp.
On the solar, the panel is mounted on a bracket with multiple holes in lower brace to adjust anywhere from flat-horizontal to near vertical. I keep it vertical for travel, and angle it up for when we are anchored. I have studied this a little, and found that when I spent a little more ($20) on the controller, then my charging and "float" levels were generally better, (13.4 volts) with float being the long-duration "trickle" that industrial batteries seem to like.
I do try to face the panel sun-ward whenever I park in parking lots and at the house.
Next projects will be manual locks for the front hubs, and a locker for the rear differential.
Adios!
jscusmcvet
Cool. As I said, you likely know more about solar than me... and here I have learned from your response. What locker are you considering? I am looking right now as well.
Jacksoneson
Weekend Wanderer
I put some a warn kit on a '78 Blazer I once had...as I recall, they worked well, went on easy, and weren't very costly.
Probably go with Warn again.
Jacksoneson
Weekend Wanderer
She a stock 1991 3/4 ton, 5.7 with TBI. 4l80E trans. with 14 bolt open rear...
My Mods:
2000w inverter
30w solar panel
(2) 100 amp/hr gel batteries mounted between the frame rails.
CB radio
High-lift jack
Custom aluminum roof rack
Rear Jerry-cans
On-board air compressor and tanks
300 watt light bar (front)
27 watt lights on sides and rear
Trans cooler
Oil cooler...
Ghostwarrior
Nice suburban. I love my suburban and been going on for 3 years.. I use harbor frieght solar 45 watts kit, it work well and i use it on my hunting camper. I leave power on so it continue charging battery when i was not using camper so i dont Have to be in darkness at hunt camp. Lol.
