Super Duty Expedition Vehicle (Turn Key)
roverbuild
2012 Ford F250 Crew Cab/Super Crew Lariat 6.7L Powerstroke Diesel (1FT7W2BT2CEC08324) Mileage 118830. This truck has every option available for the Lariat including Heated and Cooled Seats,Navigation, and Ford Sync System (Also included is Ipad Mini 4 with the Ram Mount) . This truck is also equipped with the FX4 Off Road Package, which includes the factory rear locker!
$40000
Hey Guys we have up for sale our lifetime expedition vehicle! It has been a labor of love for many many years! This vehicle is a turnkey expo rig! You could literally pick it up, fill up the fridge and drive the truck anywhere on or off road! This list of modifications are extensive and I will do my best to go through everything and get it all listed and photographed! If there are any questions or you need more photos or videos please don't hesitate to ask!
Extensive work that has been completed to the engine and all the fueling components! We have really tried to be very preventive of any and all possible failures! The list of items replaced within the last 2 years is as follows.. Turbo, All 8 Fuel Injectors with Ford Factory injectors, Fuel Filters, Fuel Lift Pump, High Pressure Fuel Pumps, S&B Performance Cold Air Intake, Transfer Flow 50 gallon diesel tank with Rhino Lined Exterior.
Snugtop VX Bed Cap with Sliding Windows and Screens, as well as the Bed Rug Carpet system. The Sungtop has been integrated with the truck so the locks work with the remote locks on the truck. Also interior lighting has been upgraded to include massive LED Interior lighting that has a separate control mounted to the inside of the truck bed! Absolutely amazing how handy these lights have been when trying to find something in the middle of the night! Inside the Bed is a Bedslide 2000 Heavy Duty Slide Racking System.
ARB Freezer Fridge with integrated Anderson power socket and Remote In Cab Monitoring
Fusion Front Winch Bumper with Superwinch 18K lbs talon winch with in cab controls & wireless remote. Synthetic Winch Line. RIGID 15K Lumens front light bar This winch combination is bar none the single greatest recovery system for super duty trucks, the 18k lb winch will pull this truck out of nearly anything!
Fusion Rear Bumper with RIGID LED Fog Lights and back up lights. These RIGID lights have been designed to work with the factory rear camera to make backing up in the dark an absolute breeze!
IBS Dual Battery Monitoring System.. Batteries in a diesel truck are the lifeline of these trucks and two batteries must be healthy at all times!
Console Vault built into the factory center console with combination lock.. When traveling anywhere in the world, it is always great to be able to safely secure your important documents even if someone breaks into the truck!
ICON 2.5”-3” Stage 2 Coilover Conversion.. This is the best of the best when it comes to Suspension Lift Kits.
Black Rhino Armory Wheels wrapped in BFG KO2 35x12.50 R20 (90% Tread)
(Spare Wheel is still the Desert Sand Color and is mounted under the truck, and Tire and Wheel are brand new)
Front Runner Roof Racks on Truck Cab and Camper Shell
Front Runner Hi-Lift Jack Mount
Front Runner MAXTRAX Mount X2
Front Runner Shovel Mount
RIGID LED Roof Rack lights that surround the entire truck, each light section has its own on/off switch!
WeBoost Drive Reach Cell Phone Signal Booster (controls in cab, antenna mounted on roof rack)
VIAIR air compressor system. 2x 485c pumps, 1x 480c pump, 2x 2.5 gallon/200psi tanks. Connectors mounted at front and rear bumpers. Compressor control located in cab with pressure gauge. Will fill all 4 tires from 20 to 65 psi in ~12 minutes, strong enough to power air tools.
1500 watt inverter located in bed, in cab power switch
200 Watt Flexible solar panel, with Sun Solar charge controller and connector in bed
OllieChristopher
Have the head studs been replaced? how about EGT sensor/EGR cooler? I did not notice you mentioning those parts as part of preventative failure replacements you had done. Replacement cost for studs (before head gasket failure) is 3,500.00 - 4,000.00 depending on if you use ARP studs or OEM.
Very nice rig BTW!!
roverbuild
Hey Guys towing capacity is probably going to be 10-12K lbs! The payload will probably be somewhere around 1500lbs!
Nothing has been done to the egr system nor have we invested in head studs being that the 6.7L Scorpion engine doesn't really have a track record of head falure!
Thank you for your interest!
chasejj
Any possibility of some additional photos of the interior and bed?
I am in the market and this looks really good.
Smudge12
