Super Duty SuperCab Rear Door Limiters
eyemgh
SuperCabs open beyond 90°. If you replace your bed and add a camper, that’s a bad combo. A little wind can bash your back door. Ford makes a kit that my dealer didn’t even know about that’ll lock them at 90°. It’s an easy install as long as you have torx sockets. Pics below.
montypower
Adventure Time!
That's great! Thanks for posting.
I do like the full opening w/o the camper... but we need to modify our camper bracket slightly for clearance. These cabs provide excellent access even with a 90 degree stop.
heinphoto
Yes, thank you for posting this! We just installed an OEV Aluma Tray on our F350 SuperCab. The tray is wider than the standard bed it replaced, and there are also some additional brackets sticking out from the side of the tray that will contact the door if I try to open it fully. I was also worried about the wind blowing the door open wider when I have it open at 90 degrees. This is the perfect solution!
sumnrfam
@eyemgh ,, is the main clearance issue down low @ the Bowen bed, or the jack brackets on the hallmark? Our F150 SCAB doors have plenty of clearance @ the CampX jack brackets,,
Great info,, thanks for the post ;-)
Wade
Macfly
Thanks for reminding me, ordered and on the way!
eclipse179
