I use both straps and KERR for a living - literally. (And I will say - MP has been very good to us and it is their KERR that we use exclusively!)
Tow straps are ideal for towing. That's what they are made for. Little stretch, (some just 3%) makes it very easy to tow for both vehicles. We tow 1 to 1 and 2 to 1 (towed vehicle in middle when brakes are compromised) there is simply no better way. What we don't want to do is impart energy or store energy and that is what the KERR does and is designed to do. A KERR is a force multiplier and if you have assessed your recovery correctly and a tow is indeed the correct response then a force multiplier is superfluous to the recovery and one could argue dangerous as it ads one more dynamic. A tow is a controlled, static, constant pull.
An experiment: Atach a rubber band to a glass and with just two fingers try to pull that glass across the counter. You will see that you first stretch the band before it actually begins moving the glass. Some of your "energy" was lost in the stretch of the band before it went to actually pulling the glass! Now, attach a string to the same glass, pull it with the same two fingers. You will see that the glass starts moving right away. All of your "energy" is being used to move the glass! You have lost VERY little of it imparting any stretch into the string! You can "tow" that glass across the counter without losing any energy in unwanted and un-needed stretch. It's predictable, easy, and safe.
A good recovery kit will have both a strap and a KERR as each serves it's own purpose. Now if a KERR is all one has then by all means use it but just understand the possible consequences and inherent problems. But given the choice I'll tow with a strap.
