Superduty ARB Bullbar
RocKrawler
Supporting Sponsor
locrwln said:
They only have a "mini-leaf" pack for a 2.5" lift for the 99-04 leaf sprung trucks. Which is what I have found most do for the smaller lifts. Either you get a bracket drop type lift or you get mini-leafs.
I am very curious about OME offering.
Jack
OME is a complete new leaf pack, doesnt get any better unless you are changing out the complete suspension to coils or airride, those both get spendy and are much taller lifts
EDIT - found that Full Traction has a 4" conversion to 4 link & coilovers... nice! http://www.full-traction.com/detail.php?MODELID=6&MAKEID=4&TYPEID=1&PRODUCTID=394&NOTES=
1999-2004 FORD SUPER DUTY -4.0",6.0" & 8.0" 4-LINK SUSPENSION CONVERSION SYSTEM
Full Traction has the cure for 1999-2004 Super Duty owners with coil spring envy. Our unique 6" & 8" lift systems convert the Super Duty's conventional leaf spring suspension to a 4-Link front axle mounting with ICG -(instant center geometry) for a true and correct caster curve throughout the entire range of linear wheel travel. ICG reduces the total caster change throughout the suspension's movement - by over 50%! The result, is a drastically improved "on center" feel, ride quality, and control when driving or towing.
This system includes all necessary components including shock mounts and a trick Nascar-style front sway bar. Astonishingly, this is a fully bolt-on system. Our engineers have created a simple, extremely strong mounting system that requires little maintenance, and is extremely simple to install. No welding is required to complete installation.
This new system is designed to accept all major aftermarket makes of 2.5" - 3.0" coilover shocks from Fox, King, Sway-a-Way, and Bilstein. You want tough? All components in this suspension system are built for maximum off road punishment or heavy duty commercial use. We use our heavy duty fully rebuildable rod ends and 2" diameter x .250 wall thickness DOM tubing for our lower leading control arm assemblies. This plus 1/4" plate laser crafted bracketry provide exceptional strength. Grade 8 hardware is used throughout. Durable Gray powdercoat finish. Shocks not included.
Goldenbora
