I thought I would throw this out to see if anyone has experienced anything similar to give me more direction.
Problem :
2004 F350 4x4 crew cab, short bed, SRW, ~120,000miles
Few weeks ago developed what I would describe as a pretty loud howling sound at any speed above 10mph, no vibration, loudest 35-55mph, drowned out by road nose above 65 but still there. Becomes slightly higher pitch at higher speed but doesn't fluctuate with engine speed, just overall vehicle speed. No change in or out of 4x4. I thought it was coming from the front end so I replaced the front wheel bearing assembly with Timken units, replaced rotors and pads (because of a bad brake pulse that had only temporarily improved with having rotors turned few yrs ago) - no change. Pulled the auto hubs to see if that was cause - no change. I Googled it and found some forums that mentioned carrier bearing or pinion bearing causing similar sound. So maybe it isn’t coming from the front. When the truck was new it had a rear end clunk and the dealer fiddled with the pinion bearing so I wonder if that is going. Driveshaft is tight, the carrier bearing looks OK, no leaking from the differential. Shifts fine, trans fluid clean and without any odors. Tires without any funny wear pattern and same tires on truck for past 40,000 miles (Michelin).
The front bearing assembly is an easy driveway job for anyone who needs to do it, I think the old hubs may have leaked lubricant from the sealed bearings because there was quite a bit of a thin light blue lubricant in the knuckle joints when I pulled the bearing assemblies, the inner needle bearings were in fine shape and didn’t lack lube. But in any case new bearing assemblies didn’t help.
Any experience with a sound like this?
Problem :
