IH8RDS
Purple People Eater said:What exactly are the benefits of a SYE?
When you lift a jeep the angles for the drive line are way out of tolerance and causes driveline vibrations. An SYE puts a double cardon joint in the rear to compensate for driveline vibes. Pretty much eliminates vibes. You have to reposition the axel housing to point at the transfer case. You can do it with shims, or more permanently, re-weld your spring perches like I did.
