Tell Me Why I Shouldn't Buy a WK CRD!
Charles R
The issue with the merc engine can be slightly more than minor seepage...
I'm sure you realise that the same basic problem can have radically different consequences depending on engine package design specifics.
While being a simple issue, the way the problem with this particular engine escalates has to do with the way the injector is set into a snug bore through the valve cover and deep into the cylinder head. Basically the injector gets glued into its spot by the seepage. The aluminum valve cover is very thin, and any prying often cracks the cover. The injector hold down bolt is a very long 6mm thing that has been known to shear if it's threads are also gummed up. There are also instances of the injector breaking in the bore... And there's reports of cracking into the cylinder heads water jacket if the hold down bolts bore is not very, very thoroughly cleaned out of any residue at the base of the hole.
So like i said... To me, a long time mechanic, it's not the end of the world... But... It has the potential to escalate into an expensive repair very quickly. So a proper inspection, by a well qualified tech, is money well spent.
To the OP... Congrats on finding a low millage one! Mine had 54k on it when i got it this summer, and i now have 62k on it. I think it's a great choice!
Charles R
I put a deposit on this vehicle, I will go to look at it in person Monday. I figured that I won't find another this clean, one owner, with only 55k miles again. I am not sure what I'll do with my 4Runner just yet.
So.... How'd it look? Enquiring minds want to know!
SSF556
SE Expedition Society
I have a set of lighty used Bilstein 4600 shocks for sale...do not need these as I went with the OME lift. These are in Greenville SC..no luck on CL and do not want to throw these away.
p nut
butter
So how's it been after almost a year of ownership? Any issues? Buyers remorse? Looks like you got some mods on there.
Utah KJ
Free State of Florida
Occasionally, I get TPS sensor drop out, apparently, the batts last about 10 years so I chalk it up to that. I had a glow plug go bad, that was an easy change. Like my KJ CRD, the rear brake pads wear down much faster than the fronts, must be a Jeep thing. My biggest issue is the WK is too pretty and in nearly pristine condition, so I am often conflicted between keeping the mods mild and using my 3rd Gen 4Runner for hardcoredness, or getting over it and putting a Superlift on it and thrash it about.
Comanche Scott
My vote is for getting it dirty!
You know the first scratch/ding/dent, is really going to hurt. But once that is out of the way, there is so much cool stuff to do and see.
Might as well just get it over with, and go have fun. :1888fbbd:
Charles R
Just go for it!
This...
Only cost this...
(Which looks much less terrible when it's not full of dust)
Now it's just an excuse to build a steel bumper! Ha!
Psyph
